Old 05-17-2017, 03:49 PM
SD421's Avatar
SD421 SD421 is offline
Default Need 1966 Upper DS Door Molding Retainer
Hi, Im in need of the retainer that holds the upper DS OUTSIDE molding.
It pushes down through a hole between the wing window and sideview mirror.
Thanks Don
PS I will add a pic later after work
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 05-18-2017, 12:37 AM
SD421's Avatar
Pics
ID:	454840   Click image for larger version
ID:	454841   Click image for larger version
1966 GTO
1966 Tri-Power
1967 670 Heads
