Old 02-20-2020, 12:37 PM
sdbob sdbob is offline
Default Harbor Freight 12 speed Bench Top Drill Press comments
Bought a 12 spd bench top drill press for portable use.Sometimes I need to drill steel away from shop.
I waited till price was low. Anyway no matter what speed I've tried the motor does not have torque. Drilling 1/8" steel with sharp 1/4" bit,grabs then stalls motor, time consuming, battery hand drill better. So local motor repair shop finding used motor for me. So beware.
Old 02-20-2020, 02:20 PM
cdrookie cdrookie is offline
Take it back. There's always smaller drill presses on craigslist and marketplace.
Old 02-20-2020, 03:50 PM
dataway's Avatar
dataway dataway is offline
I got the Wren 12" variable speed at Home Depot for a job I had to do with some very long metal that I couldn't get into my other machines for lack of room. Figured it was worth it for the one job even if I destroyed it in the process.
https://www.homedepot.com/p/WEN-12-i...4214/204994931
To my surprise I'm still using it, it's actually not bad for a chinese piece of garbage. The variable speed, digital readout etc. work pretty well.
However it will require the usual partial disassembly, proper lubrication etc. If it starts making a funny noise ... you have to pull apart the drive and get some lube in there.
With some proper spindle bearings and a chuck that isn't total crap it would be even better.
Course if you can find a used US built unit that would be a great option too ... make sure it's a name brand that you might still be able to get parts for, or that uses standard industry parts.
Old 02-20-2020, 08:05 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
When buying anything with an electric motor, from whomever, look at the amps. While there is more to it, generally more amps allow for more power. According to the HF specs (unless it’s a misprint) this drill press is rated at only 3.85 amps which seems pretty low for a press with a 5/8” chuck capacity. I have hand drills with more amps. That said, with that amperage you should have no problem drilling 1/8” steel. Either the 3.85 amps is over rated or it’s a bad motor.
Old 02-21-2020, 12:11 PM
Thanks for input. I just hope the castings dont break when I get a good motor. It's just sometimes I need a drill press out somewhere to drill alot of holes in steel usually 1/4" thick stock,time consuming with hand held. I never know what I'm getting into sometimes,'oh yeah I'll help'!
Old 03-08-2020, 07:18 PM
Does changing the belt configuration(spd) help? Nice one on CL Barto pa(Allentown CL)
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 03-10-2020, 01:21 PM
Tried low speed,higher speed,medium speed. Still stalls. Motor as was said doesnt have the torque. Funny that a 3/8 old Sears can do a better job. I'm getting higher torque motor as soon as shop can find one in their stock of used. You need one with bearings because of vertical application. I have their table top belt sander it works but there again you can stall it applying to much pressure. Live and learn to read specs.
Old 03-10-2020, 02:08 PM
SRR's Avatar
SRR SRR is offline
Had one from HF a few years ago, same problem. No power.
― Calvin Coolidge
Old 03-10-2020, 03:43 PM
ignaro's Avatar
ignaro ignaro is offline
My philosophy is to always buy the HF tool first. If/when that breaks or fails, do some research and spend a little more.
I've wound up replacing 1 out of 10 things, saving much more money this way in the long run. That drill press is likely fine for woodworkers doing little hobbyist jobs. I have the same-size band saw and rebuilt all my kitchen cabinets with it. Works great but no doubt it would fail if I tried to do heavy lumber, let alone steel.
Old 03-11-2020, 07:53 PM
Shoulda- coulda- woulda- saved my money and bought a mag drill! Then I wouldve had a drill I could drill in all positions in metal. Looking at Dewalt.
