Old 11-18-2020, 06:24 PM
tom s tom s is offline
Yes Stan just one non factory head build.Too many RA Vs!Tom
  #42
Old 11-18-2020, 06:45 PM
Stan,Ric Johnson in his 62 Cat ran 10.91 123 at 3750 with 980 heads and 10.13 133 at 3450 with Indy ported 62s.
Dave Johnson ran 9.80 at 130s at 3200 lb with 980 heads.
Have not talked to Blair or Nunzi yet.
  #43
Old 11-18-2020, 07:07 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Information on Marty I printed YEARS ago... INSPIRATION then and now.
click and zoom for a larger copy
*** THE BIG BRACE is here ***
  #44
Old 11-18-2020, 07:33 PM
Blair Tempest 9.33 142 @ 3200
Rudy’s Astra in 1978 8.80 @151 no weight
  #45
Old 11-19-2020, 01:14 AM
Stan Weiss's Avatar
Tom,
Thank you.
Stan
Pontiac Pump Gas List
  #46
Old 11-19-2020, 01:16 AM
Stan Weiss's Avatar
Thank You.
Stan
  #47
Old 11-19-2020, 01:17 AM
Stan Weiss's Avatar
Tom,
Thank You.
Stan
  #48
Old 11-19-2020, 03:02 AM
Dragncar Dragncar is online now
Marty ran Eagle rods ?? Never would have thought that. Got the job done at any rate.
One of the best looking GTOs ever.
  #49
Old 11-19-2020, 02:00 PM
ta man ta man is offline
Mike Voycey was another who ran deep in the 9's.
  #50
Old 11-19-2020, 02:53 PM
Joe's Garage Joe's Garage is offline
Default Our 1985 TA ran 10.23@131mph with stock block and heads
Couple years ago at LVMS = 1,980ft. Probably 90* air temp and low humidity.
Engine was getting tired at that point, so probably really low 10s or high 9s when freshened (happening now)
2900 lbs empty, around 3075 with driver.
1968 428 block, stock crank, +.030 good pistons and rods
ported 1968 RAII heads
Torker with 850 Holley
big roller cam
Hoosier radial slicks
4500ish stall T400 4.10s
I'll have to see if I can find a timeslip.
  #51
Old 11-19-2020, 03:30 PM
Stan Weiss's Avatar
Thanks.
I have a build of yours on the
Pump Gas List.
Are there any updates?
Stan
  #52
Old 11-19-2020, 03:31 PM
Stan Weiss's Avatar
big roller cam
Thanks. I have updated the list
PMD Heads and Block List.
Stan
  #53
Old 11-19-2020, 05:34 PM
Originally Posted by Stan Weiss View Post
Thanks.
Pump Gas List.
Stan
Yes..new but somewhat same build..will send details..is that an open thread somewhere?
  #54
Old 11-19-2020, 06:21 PM
taff2's Avatar
taff2 taff2 is offline
My old 406 combo used a 557 block, diy ported '69 no 16 heads, 13-1 compression, 7" ali rods on a 350 ordinary iron crank, Crane 250 degree solid flat tappet cam, ported Torker 1 intake with a 2" spacer and a Holley 800 spreadbore double pumper, 2" headers, it made around 575 hp at 7000 rpm, ran 9.61@137mph. I used it for around 3 years, hundreds of runs ,sold it still running fine. ps ,the car was around 26-2700lbs
  #55
Old 11-20-2020, 02:43 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Does the list exist now?
  #56
Old 11-20-2020, 10:54 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
  #57
Old 11-20-2020, 03:41 PM
70 bird's Avatar
70 bird 70 bird is offline
Should start a 557 block list.....you might hold the record there! lol.
  #58
Old 11-20-2020, 06:05 PM
Stan Weiss's Avatar
Stan
  #59
Old 11-20-2020, 06:59 PM
hp 400 dave's Avatar
hp 400 dave hp 400 dave is offline
68 Firebird 3,540 lbs., 406 cid, glide, 4:88 gears, #62 230cfm, flat tappet cam, 11:17 at 121 mph, 1998 E - town.
  #60
Old 11-20-2020, 07:53 PM
Stan Weiss's Avatar
Thank you. I have updated the list
Stan
