66-67 LeMans / GTO sheetmetal
Pair of front fenders, believe are 66. Hollander #1309/1371. Left is perfect $250, Right has small hole at bottom $150. Pair of inner front fender skirts, believe '66-67 Pontiac A only, w/ good battery tray. $175 pair. Trunk lid, believe hdtop, Hollander #790. Dented, but clean rear edge and around lock cylinder area. $95. Hood hinges, 64 - 67 Pontiac and Oldsmobile A body. Clean, tight, and already blasted. Hollander #152. $100. Pair of plastic grille inserts, LeMans. Fair but usable condition. $50 all. Misc. window and wheel opening stainless trims, not complete sets but VG. $125. Dashboard passenger entry pulls - LeMans scripts. $20 and $25 ea. Located near Las Cruces NM zip code 88007.
What year are the grille inserts? If they are '67 I'd like to see some pics. Tnks
Most of this is still available, believe inner skirts sold, and hinges were not Pontiac A body. Still have both outer front fenders. Dave S dona Ana NM
Let me know if the skirts don't go away...thanks
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
Wouldnt happen to have a 65 66 67 gto hood would you?
66-67 Le Mans sheetmetal
Still have access to these parts - were dumped at local yard for scrap. Saved and Set aside in sheetmetal area.
to the top. Still available.
'66 Fenders, Right and Left. Le Mans. '66 Trunk Lid, Le Mans. '66?-'67 Front inner skirts, believe from same '66 Lemans pile. Hood hinges were in same batch, turned out to be RV hinges. My mistake, sorry. Still have stainless window trims, are also in a separate ad, thanks. Plastic grille inserts were all likely '66 Le Mans, were placed inside shop garage at yard, Remember as being in fair to okay condition, some cracks, may still be there, can furnish their contact info if interested. |
66 Le Mans sheetmetal still available
Front fenders Front inner skirts will do $125 pair if some one is interested Trunk Lid Rear window surround trims |
To the top.
