Old 12-06-2020, 02:31 PM
napster's Avatar
napster napster is offline
Default Ram Air Series Cam from Butler
I'm having an engine built for my 1969 GTO. Decided to make it a ram air car.
I looked for some 722 heads to no avail and stumbled on to the RAII heads Pictured
ID:	555534   Click image for larger version
ID:	555535   Click image for larger version
ID:	555536   Click image for larger version
ID:	555537   Click image for larger version
Old 12-06-2020, 02:36 PM
napster's Avatar
While I was at it I came across the following new cam from Butler. Thought I would give a try.
Engine will be .60 over and with a 427 stroker kit will equal either 440 or just shy of 440 CID. Compression will be 9.9 and using RA IV exhaust manifolds.
Should be an interesting build.
ID:	555539   Click image for larger version
Old 12-06-2020, 02:56 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The intake/exhaust lift is opposite of what a RA II head generally likes. It will probably run better with a 1.65 rocker on the intake and a 1.5 on the exhaust... Seems like a cool build!
Go fast, see Elvis!
Old 12-06-2020, 03:06 PM
This is a flat tappet Hydraulic Camshaft? Like Factory?
Do not understand the HR at the end of the part number. (HR typically means Hydraulic Roller).
Old 12-06-2020, 03:09 PM
I was assuming it’s a hydraulic roller from the card?
Old 12-06-2020, 03:13 PM
Formulas Formulas is offline
Would the extra exhaust lift come in handy with iron exhaust manifolds
Are the heads dated D228? If so production heads are a little more desirable than service heads. Looking at the picture both will be D228.
Old 12-06-2020, 04:00 PM
PAUL K's Avatar
Probably not for a street type application. Eventually if the engine is spun high enough the added lift will help.
Go fast, see Elvis!
Old 12-06-2020, 04:02 PM
STEELCITYFIREBIRD's Avatar
Took a look at their new cam offerings. Indeed a Hydro Roller. RA seems only a name!
https://butlerperformance.com/c-1234...by-butler.html
Old 12-06-2020, 04:04 PM
PAUL K's Avatar
Hi Tom, yes that is a hydraulic roller cam. Butler offers a "Ram Air" series of HR cams now.... As you know the Butlers are great with marketing.
Go fast, see Elvis!
Old 12-06-2020, 07:06 PM
Agree, David Butler has made good use of that Business Degree (over the years that he has run Butler Performance).
Old 12-07-2020, 01:34 AM
Brian Baker's Avatar
Hydraulic roller version of the venerable 041 grind will run well with those heads and around 440 cubes.
Old 12-07-2020, 08:25 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I end up building quite a few carburetors for engines done there or from folks who have bought parts there.
For quite a few years they pushed a LOT of XE cams and most of their custom stuff was ground on 110LSA's for quite a few years. The XE268, XE274 and XR 276 HR were high on the list.
It's probably been 3 or 4 years now if not longer, but after a phone conversation with them about an engine they were dyno tuning I sent them the cam card comparison below.
Things have changed quite a bit since then, if anyone is paying attention.......
Old 12-07-2020, 11:33 AM
Kind of what I was thinking.
Old 12-08-2020, 02:52 PM
napster's Avatar
These are early heads without the 96 above the center ports. The 96 was added later to aid the assembly line workers. The first service replacement heads were dates in January, 1969.
Look at post #25 by The Boss in the link for the dates of production for the RA II heads.
http://forums.maxperformanceinc.com/...04#post5256604
Old 12-08-2020, 04:55 PM
sberbs's Avatar
sberbs sberbs is offline
So what was the custom grind stats?
Old 12-08-2020, 06:42 PM
pastry_chef's Avatar
Here are both cams.
Smaller 276 roller on 110 LSA
Intake
3314
276 @ .006
224 @ .050
145 @ .200
.335
Exhaust
3315
282 @ .006
230 @ .050
151 @ .200
.340
OF roller on 114 LSA
Intake
3122
290 @ .006
236 @ .050
160 @ .200
.3800
Exhaust
3120
304 @ .006
244 @ .050
161 @ .200
.3830
I don't see LSA... just a chit ton of AREA difference - same as the engine.
Here is another 455 dyno with 250 CFM d-ports (I think they did more than 70 pulls) using the smaller roller - https://www.hotrod.com/articles/hppp...e-stuska-dyno/
Another member Tom S used the smaller cam on a stock iron dport 455, made 432 HP.
FYI,my 455 with a stock set of 48s,9.5 CR and a comp 276 hyd roller cam,224-230 on a 110 made 432 at 5100.Stock 69 QJ,stock unmolisted 69 intake,etc.Just a pump gas 455 RA III type build.Tom
Old 12-08-2020, 07:06 PM
They added the 96 the next day D238
Old 12-08-2020, 07:17 PM
With the round port exhausts and the smaller D port sized intakes I'd flow the heads before I bought a cam. Betting a single pattern or a "reverse" split like my RAIV heads liked.
Old 12-09-2020, 01:44 PM
napster's Avatar
Skip,
I was thinking of the attached cam before I saw the RA series cam. The attached cam is being used in my 1970 T/A. It has 614 heads and is a 433 CID engine. It runs very well.
