View Poll Results: What type of oil do you use?
Synthetic 37 34.91%
Conventional 55 51.89%
Blend 14 13.21%
Voters: 106. You may not vote on this poll
Old 06-09-2013, 03:09 AM
aktattoo's Avatar
aktattoo aktattoo is offline
Default Poll Synthetic/Conventional/Blend
What do you use?
1970 Bonneville Convertible
Old 06-09-2013, 03:37 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
I use 4 quartz 10/30 Valvoline, and 1 quart of 5/30 Mobil 1 the advantages of both for summer and winter. BUT I live in SoCal, not much of a winter.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 06-09-2013, 04:49 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Valvoline VR-1 conventional here.
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 06-09-2013, 05:33 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Brad Penn 10w- 40. Its a blend
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 06-09-2013, 05:36 PM
Old Goat 67's Avatar
Bret P.
Me too. And ONLY Valvoline.
Old 06-09-2013, 05:39 PM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
A good conventional 10W-30 with a shot of GM assembly lube.
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
Old 06-09-2013, 05:43 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
I just switched to this http://www.amazon.com/Valvoline-VV17...alvoline+5w-30
Karl
Old 06-09-2013, 05:56 PM
Hillard's Avatar
Hillard Hillard is offline
AmsOil in everything...street, race, trans, differential. Proven performance.
Old 06-09-2013, 07:10 PM
73T/A 73T/A is offline
Same here Valvoline VR-1 silver bottle!
2001 Trans Am,WS6 Sunset Orange Metallic (sold)
1973 Trans Am 455,4speed
1970 GTO
Old 06-09-2013, 08:38 PM
Hillard's Avatar
I'm a little shocked that synthetic isn't winning by a landslide. I know someone who used to run super stock and claims to have seen extra hp (5-10) on the dyno with a simple oil change from conventional to synthetic. I know someone else that has seen a 2 mpg increase by switching to AmsOil. I can show you an engine right now with over 200k that used synthetic for at least 150k of those miles and is still super clean inside even though it only got changed once a year.
The increase in power and better fuel economy is obviously a result of less friction. Less friction will equal longevity. There is no downside. I've used AmsOil in every vehicle I've owned over the past 15+ years....street and race, flat tappet and roller cams. And yes, I've compare it to conventional oils. I can't find any reason to run anything else.
Old 06-09-2013, 09:36 PM
tom s tom s is offline
syn with roller lifters and dino with eos and stp for flat tappet.Tom
Old 06-09-2013, 10:23 PM
tqvhp's Avatar
tqvhp tqvhp is offline
Amsoil in all my rigs
Old 06-10-2013, 05:11 AM
Hillard's Avatar
Not the first time I've heard this. Why not synthetic for flat tappet? I've done it numerous times.
Old 06-10-2013, 06:17 AM
Just curious about this myself. I would think the rollers wouldn't need the "higher quality" oil since they roll over the cam not rub. Is it the higher spring pressure on the roller? I'm no chemist so I'm just assuming the synthetic is the better overall oil. What is it in the properties of the two that would make one better for flat tappet vs. roller?
Thanks,
Uneasyrider
― Socrates
― Socrates
― Plato
Old 06-10-2013, 07:49 AM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
Used to run conventional Castrol GTX 10W30 in everthing with zero issues. I now run synthetic
Mobil1 10W30 in everything with zero issues.
Old 06-10-2013, 09:09 AM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Bret P.
Same but have added the ZDDP additive.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 06-10-2013, 09:51 AM
pngoat pngoat is offline
Mobil 1 10W-30 with 1 quart of Rislone engine oil supplement. (zinc additive). No issues.
Old 06-10-2013, 10:42 AM
Here is some good information on conventional vs. synthetic motor oil.....
http://www.bobistheoilguy.com/motor-oil-103/
Karl
Old 06-10-2013, 12:11 PM
Poncho-V's Avatar
Poncho-V Poncho-V is offline
Default Amsoil in everything
Amsoil in everything.
Old 06-10-2013, 12:43 PM
i82much's Avatar
i82much i82much is offline
I don't know if this is the right answer, but I guess I've always kind of looked at things the other way with an old car with a carb. I figure unless your engine is tuned perfectly chances are you have unspent fuel or combustion byproducts polluting your oil, so why not use a conventional oil and change every 1500 miles or so?
