Old 06-27-2013, 10:13 AM
chiphead's Avatar
chiphead chiphead is offline
Default Front suspension torque values?
Car is '67 LeMans with disc brake conversion. I've done some searches and looked in my vintage chilton manuals but I can't find all the torque values for the front end.
I need the torque values for:
pitman arm to steering box
center link nuts torque
tie rod ends
upper ball joint
lower ball joint
steering arm to spindle bolts
UCA shaft to frame nuts
LCA to frame bolts
Old 06-27-2013, 11:08 AM
pngoat pngoat is offline
Hope this helps. All specs in Lb.Ft.
Pitman arm to steering box: 110-140.
Center link nuts: 30-40.
Tie rod ends: 30-45.
Upper ball joint: 55-70.
Lower ball joint: 85-100.
Steering arm to spindle bolts: 60-75.
UCA shaft to frame nuts: 45-60.
LCA to frame bolts: 75-100.
Good luck.
Old 06-27-2013, 10:49 PM
chiphead's Avatar
The lower control arm bolt torque sounds high, that bolt/nut isn't that big. The rest seem dead on. Thanks!
