Wipers park in wrong position
Ok I got my wipers "working" in the sense that if I leave the third ground screw out of the firewall the wipers work fine but they dont park. If I turn the switch off they just stop wherever they are. If I put the bottom ground screw in they go up to the full swing position and stop and then the switch does nothing. What have I done wrong?
It needs the ground so the motor continues to the park position once you turn the switch off. There's an internal switch that shuts the power off when the wipers are in the park position.
Seems like the internal switch is out of position somehow. George
As George stated the ground screw allows the wipers to park once the switch is turned off. However your problem may be mechanical rather than electrical. I have a 65 GTO that parked in the full swing position as yours does. I removed the wiper arms and the cowl grill. I removed the arm on the wiper motor and turned it 180 degrees. Now the wiper arms park in the proper position when the switch is turned off. I'm not saying this is your problem, but, may be something worth checking. Hope this helps. Good luck.
stupid question but could you not just take the motor loose and reposition the linkage back to the bottom and hook it back up without having to take the cowl off and all that? Getting the wiper arms off is a bitch
Does your wiper arms not have something to release pressure on the spring loaded retainers? Some have a hole that you can slide a nail through when you raise the blades up off the windshield. Have you had the wiper arm transmissions off? If the arms under them are off 180° it causes the same problem. Might take the motor loose and wiper arms off then fanagle with it to get the arm transmissions lever rotated a half a turn. IDK clearance on the tie rods is what you have to look out for. Good luck with which ever one it is. The motor arm or the levers on the back of the wiper arm transmissions. It's gonna be one of the two thats 180° off. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
