Door Jamb sticker
I need to replace this door jamb sticker and I don’t recall what info was on the sticker to begin with...can anyone help me with what information should be on the sticker and where can I get one .
I’ve seen some where u can type in the info but how good does that work ??? I would prefer something that I can get pre filled .. ...any help is appreciated thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Serial number and build date. The date is still on this 10/71, serial number goes lower in middle about in line with GM emblem.
I have seen ads for this service. Sent from my Moto Z3 Play using Tapatalk
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
1973 is Not like a 71. There are weights added at top
Just started working on a 70 Judge early build 11D..... has no rolled lines on the inner door for the VIN conformity label. I believe the doors are original to the car.
Should have mentioned this is for a 73....
So we have the vin build date and weight anyone have a pic for reference
Best place is ecsvin.com for door labels
http://www.forums.maxperformanceinc....d.php?t=759904
http://www.forums.maxperformanceinc....d.php?t=835969
So long, farewell. |
Interesting thread.
Mike, I'm confused. In the linked thread, I see the '73 weight with AC as 4741. But the sticker you posted shows 4791 with 50 extra lbs on the front. Sticker is for a Formula, is that the difference? Is the '73 TA lighter than the '73 Formula? What am I missing? |
Wondering the weight for my car ...73 plain Jane originally 350/350 turbo no ac....
weights on stickers were based on a combo of base + RPO Codes ( in General)
HD battery / cooling can change the weight, as does dual exhaust, M40, vs M38... C60 adds a lot. I saw 2 late 72 and cars were nearly identical, but one was a 4 bll, one two and one had deluxe interior. The 4bbl car weight like 30 lbs more .... |
Probably the reason I copied that conformance sticker. Here is another '73 sticker. Also posted the '74 chart here. http://www.forums.maxperformanceinc....4&d=1581994949 As you can see they broke it down more and maybe that started near the end of the '73 model year.
Mike, I see the '74 Chart was first issued in late Feb '73. I can't make out the Revision Date when it was Retyped & Revised. But I wonder if the '73 Chart was ever revised from the version you have?
Looking at the '74 Chart, I also noticed the Note 2 stating "Information from Chart or Car Manifest." That reminded me that similar Weight Information can be found in the 1964 Tempest AMA Specs. Those Specs list the 6 cyl and V8 base wts and the various additions for Auto Trans, Power Steering, GTO option, A/C, and 1 or 2 others. So I wonder, does anybody have the MVMA Specs for the '73 Firebird? It might provide the specific option weights that affected what was shown on the actual Car Manifest and consequently the Conformance Label. I have the '64 AMA Specs because PHS used to provide a copy of it with the '64 record. Could be the '73 Chart shows the base weights and the MVMA Specs might show the weights to be added to the base weight for various options similar to how it was done in '64. |
I believe the MVMA listed the shipping weights, not the GVWR.
