Old 01-12-2001, 12:33 AM
JOE V JOE V is offline
I WANT TO RUN THE RAM AIR CABLE THROUGH THE FIREWALL BUT NOT SURE WHERE IT COMES OUT FROM. SHOULD IT COME OUT NEAR THE POWER BRAKE BOOSTER OR NEAR THE THROTTLE CABLE?
I HAVE A 69 GTO
THANKS
JOE V
I HAVE A 69 GTO
THANKS
JOE V
Old 01-18-2001, 10:13 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
Joe,here is where the cable is routed on a '69 Judge firewall.I measured from the top of the steering column where is comes out of the firewall,and up 4 3/4 inches and to the left 2 1/2 inches.You will probably have to take off your wiper motor to get to this area.There is also a rubber grommet in the hole where the cable runs through.
The hole is located on the very right corner of a ledge that angles inward just below the hole.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 01-18-2001, 10:46 PM
JC455 JC455 is offline
Now that's what I call a diagram! I'm not positive, but I believe I read that roughly in that location there should be a dimple. This would facilitate a rapid drilling spot on the assembly line.
John
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
