Old 01-10-2021, 03:26 PM
beertracker's Avatar
beertracker beertracker is offline
Default cam degree
Is it possible to degree a cam without the profession crankshaft turning tool as shown below? If yes, how is it performed? https://www.youtube.com/watch?v=rXuATjw4LQ8
I have a degree wheel, pointer, magnetic base & indicator, piston stop and Pontiac crankshaft bolt.
Old 01-10-2021, 03:39 PM
ta man ta man is offline
A crank socket is cheap.
Old 01-10-2021, 04:53 PM
77 TRASHCAN's Avatar
If the flexplate/flywheel is installed you can use one of those tools that grab on the teeth to turn the crank...
Shut it off
Shut it off
Old 01-10-2021, 05:23 PM
I have a couple of "professional" style (Large Diameter degree wheel) tools.
One, I made using a degree wheel of flat steel 14" in diameter that bolts to a factory
Pontiac Harmonic Balancer "Hub". Install the hub, install the Crank 15/16" socket bolt,
and then zero the degree wheel by moving the wheel (with slots) that align with the Factory balancer pulley bolt pattern. Eack slot allows about 40 degrees of movement.
The second Degree Wheel system was purchased from a well known Automotive Racing Tools supplier. It has an even larger wheel and a hub that allows rotating the wheel anywhere in a 360 degree circle. Everything is billet aluminum except for the Hub itself.
Speed your money on good stuff of a large diameter. Accuracy in degreeing cams will be much higher. Make or buy a good piston stop tool too.
Old 01-10-2021, 06:21 PM
tooski tooski is offline
The answer to the question is yes. I have done it via rotating the flexplate as was mentioned. It was a real PITA. I bought one to set up my engine up to TDC for distributor install (and for next cam install). Far easier to rotate the engine in either direction.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 01-10-2021, 07:21 PM
thanks, here is the degree wheel I have. https://www.summitracing.com/parts/sum-g1057-16 If I had known all the required tools for this job up front I would have never started it.
Old 01-10-2021, 08:17 PM
4dblnkldude's Avatar
Tooski nailed it. I just did this today. It would have been nice with that tool but...it still worked out.
Old 01-10-2021, 10:04 PM
Tighten the crank nut down tight, then use a socket. Is not going to loosen with the spark plugs out.
Bill Nye.
Old 01-11-2021, 10:43 AM
Lee's Avatar
Lee Lee is offline
Degreeing the cam with JUST #1 piston/rod installed also makes it a bit easier to turn.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 01-11-2021, 12:16 PM
grivera's Avatar
grivera grivera is offline
The crank nut tool is a godsend to do this with.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 01-11-2021, 02:42 PM
Who sells Pontiac crank sockets???
Shut it off
Shut it off
Old 01-11-2021, 02:48 PM
TransAm400 TransAm400 is offline
I have the Comp Cams kit and it came with one. You can probably buy it separately from them.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 01-11-2021, 05:24 PM
Will Will is offline
This.
I have also just used a big crescent wrench on the crank snout with the crank key installed. Gotta be careful not to damage the key though. Easier on engines with viton vs. rope crank seals.
Old 01-11-2021, 09:53 PM
grivera's Avatar
https://www.benchmarkarizona.com/pro...SABEgJFdfD_BwE
Will Rivera
Old 01-11-2021, 11:24 PM
Originally Posted by grivera View Post
Well, I know what my next specialty tool purchase will be. That's slick!
Old 01-12-2021, 02:06 PM
Originally Posted by Will View Post
This.
This is a disaster waiting to happen.
Old 01-12-2021, 04:33 PM
Yeah, I can see that. I guess I got lucky.
At least I knew what the potential hazard was and could be careful about it.
But, putting a crank bolt in the snout works fine and is a much better way to do it if you don't have one of those crank sockets.
Old 01-12-2021, 06:58 PM
That crank socket looks like the Comp one. I have one with a wheel for Pontiacs and one for SBC that I used on the 409(they have a SBC snout just the keyway is different spot) That way once I get it cranked down tight on the wheel I don't have to worry next time if it was tight.
Old 01-12-2021, 06:59 PM
The trick with the crank bolts is to add some thick washers to it to take up the thickness of the balancer keeps guyss from bottoming out the bolt and screwing up the threads.
The Following User Says Thank You to ta man For This Useful Post:
Old 01-14-2021, 01:56 PM
Agree, it's near impossible to get TDC correct with out it.
2007 Grand Prix GXP 5.3L
