Old 07-26-2012, 07:54 PM
Hwkw69 Hwkw69 is offline
Default 69 firebird rocker molding
Does anyone know what installs on the fenders on a 69 bird that the molding attaches to? There are 2 round holes and 1 rectangular hole at the bottom of each fender. I bought new molding and mount kit but nothing is included for the fenders. Need help.
Old 07-26-2012, 09:09 PM
nashcar nashcar is offline
Hit the search this forum and you'll find it was discussed at length.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 07-26-2012, 10:31 PM
Old 07-27-2012, 12:11 AM
Firebob's Avatar
Firebob Firebob is offline
There are two flat steel mounting plates per side that screw to the car and the rocker trim slips over them and screws go up underneath the bottom of the rocker to fasten them on. There is also a square plastic push in screw anchor that fits into a square or rectangular hole in the front fender. Nothing in the round hole. The back of the trim just has a srew that goes through and into a drilled hole in the body.
Robert
Old 07-28-2012, 11:57 PM
dexter551 dexter551 is offline
Default Rectangular hole for trim panel
I had the same trouble locating the correct fasteners. I found that the round holes are not used for anything? The suare hole has a type of well nut that clips into the hole and the panel is then screwed to the nut.I think the Fiher body manual has a picture of this. I found mine at the local Ace hardware store for 50 cents each. They were a little to long but I just used the flat side of the grinding wheel to take about 1/8" off. They work great have had no problems. Hope this helps!
Old 07-29-2012, 02:04 AM
A Schab A Schab is offline
I think that the round holes in the fenders are for the posts on the Sprint emblems that are on the rocker moldings.
Old 08-08-2012, 08:08 PM
Cammer-6 Cammer-6 is offline
youre correct
In 67 and 68 they were Sprint fenders only
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
