Old 10-09-2013, 11:49 AM
dexter551 dexter551 is offline
Default 69 Firebird AC heater control vacuum lines
Does anyone have a picture or diagram of how the 4 vacuum lines are attached to the vacuum switch on the heater control? Someone over the years pulled out the 4 vacuum hoses from the rubber plug that connects to the unit instead of prying off the rubber plug. There are 2 slightly longer ones that seem to go to the back of the plug but I know it will make a difference as to the location.
Thanks!
Old 10-10-2013, 06:15 PM
69Farburd's Avatar
69Farburd 69Farburd is offline
I hope the attachment worked. It is from a '67, but the principal should be the same. Put the AC control on inside air, and hook the hose that has vacuum (probably the longest one) to the door located in the passenger side kick panel so it closes that door. Put the control on defrost, and hook the hose with vacuum to the door that allows air to come out of the defrost vent. Do the same for the heat door, and air door and you should be set.
Old 10-10-2013, 09:38 PM
FBird69's Avatar
FBird69 FBird69 is offline
Does this diagram help?
Name:	Page 18 from AC F-Car 1967-73.jpg
1969 Firebird Convertible 400 Ram Air/HO (WQ), 4spd (M20), saf-t-track, hood tach, A/C, P/B, P/S, AM/FM Stereo, P/A - (24 options on the PHS)
My album: http://forums.maxperformanceinc.com/...hp?albumid=665
