Old 01-14-2021, 10:43 PM
fyrffytr1's Avatar
Where in the world does time go? It seems like only a month ago I was ready to get the 50 driving. How did two and a half years go by! I have finally got back on the 50 and actually drove it around the yard yesterday but the water pump is bad so I have to replace it. If nothing gets in my way I will do that tomorrow. I also washed the car for the first time in over 40 years. I took everything out of the interior then rolled the car outside and washed the inside and outside down. Brakes are done and new fuel tank is hooked up. I have to pull the radiator so I can remove the water distribution tube to check it for corrosion. It's like pulling the camshaft and that is why the radiator has to come out. Thankfully I had already removed the grille and front bumper.
ID:	558470   Click image for larger version
ID:	558471   Click image for larger version
ID:	558472   Click image for larger version
Old 01-16-2021, 12:49 AM
fyrffytr1's Avatar
Well, the distribution tube was in good shape so I will clean it up and put it back in. I am going to pick up a fan belt tomorrow along with radiator hoses and a thermostat then I can start bolting the motor back together. I flushed the block and radiator so everything should be good to go.
Old 01-18-2021, 12:31 PM
mr67gp mr67gp is offline
I really like the lines of that '50. Glad you are back at it.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
The Following User Says Thank You to mr67gp For This Useful Post:
Old 01-19-2021, 11:19 PM
fyrffytr1's Avatar
I drove it around the block this morning. First time the car has moved any distance under its own power in over 40 years. Now to work on the floor pans and teach myself to MIG weld! This ought to be fun!
Old 02-08-2021, 02:14 AM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
cool. I still get to everything you started doing at the beginning of this thread with my 50 coupe. If you find you won't be using the two-carb intake, let me know.
See ya back on the HAMB
Roll around in the excitement
The Following User Says Thank You to Rocky 389 For This Useful Post:
Old 02-22-2021, 12:20 AM
fyrffytr1's Avatar
Here's a video of the car moving for the first time in 50 years.
https://www.youtube.com/watch?v=XijMg8Ns1Ew
Old 02-22-2021, 01:40 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Good for you!
Forward AND backward!
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 02-22-2021, 10:20 AM
moneypit's Avatar
moneypit moneypit is offline
Congrats!
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
The Following User Says Thank You to moneypit For This Useful Post:
Old 02-22-2021, 10:52 PM
fyrffytr1's Avatar
Originally Posted by Jack Gifford View Post
Good for you!
And no smoke! Original straight 8!
