Old 01-08-2021, 06:23 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Quick update...
1969 Poly Bushing
PST # (POLY34114)
The kits missing the inner front fender bushing, what the hell. Shop had to order them separately and pause completion.
The bolts on mine were only tough to get out in the front fender area. I'll find out soon but it's looking like 15+ hours of shop labor to do this on a factory original 1969 Convertible GTO body bushings on a car from the IL area.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 01-08-2021, 07:09 PM
vertigto's Avatar
vertigto vertigto is offline
Per the website filter, I ordered SKU: POLY34115 for my 1970 GTO. I would've thought it would be the same kit for 1969 and 1970.
Wonder if that set is also missing the inner front fender bushings?
Old 01-15-2021, 01:37 AM
GOAT8U2's Avatar
Check out how rusted, compressed and cracked the 50 year old bushings were.
I got no complaints about the AMK bolts from the mechanic.
ID:	558481   Click image for larger version
Old 01-15-2021, 05:05 AM
dataway's Avatar
dataway dataway is offline
Will probably ride and handle a bit better with that mess out of there
Old 01-15-2021, 03:46 PM
Brewster's Avatar
Brewster Brewster is offline
It will ride way different. I remember doing it to my 72 formula and was a big improvement. I need to do my vert since it too sports her originals. Let us know thoughts about the ride??
Old 01-15-2021, 06:57 PM
GOAT8U2's Avatar
They had to remove the Fender Wells to get at the ones tucked away in the Fender area.
Then I never heard back from PST on if the kit I bought was just missing the 2 bushings or if that's how the kit comes.
I have a new issue which is the radiator core support is rusted away where the bushings meet the core support bottom. Looks like I'll have the body shop repair it and paint match it to the body repair. I guess I'm doing fender wells and firewall now and start a partial engine body resto while the engines out.
Old 01-15-2021, 09:55 PM
vertigto's Avatar
I've called PST a number of times to check on the 70 kit I bought from them and sat on indefinite hold each time. Wonder what's going on?
The pic for POLY34115 shows 3 more bushings (31 vs 28) than your 69 kit (POLY34114), which makes no sense (odd amount?) and I'm sure the image is just 'representative '.
Guess we'll see...
Old 01-18-2021, 10:47 AM
vertigto's Avatar
Another PST question...did anyone receive a tube of the 'polylube' to use when installing the bushings or just use white lithium grease? Assuming to eliminate any noise/squeaking?
Per the PST website FAQs -
Do I need to lubricate Polygraphite bushings prior to installation?
It is best practiced and highly recommended that the polylube that is provided with the PolygraphiteŽ bushings be used. Apply liberal amounts of polylube during installation. If polylube is unavailable, good quality white lithium grease can be used.
