#41
My 15s are still as greasy as the day I pulled them off 20 years ago and bone stock! Shipping might be a killer from Texas. 62 is tanked years ago and surface rust.
#42
Has this engine been DE-tuned for pump gas?
Does the 4bbl open all the way when you mash the gas pedal? IMO Project like this would need some high octane fuel with a "performance" tune-up. Clay |
#43
Sent from my SM-N960U using Tapatalk |
#44
That's why I asked him to pop the other valve cover.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
#45
#46
Hi OK, is the pic from post 16 the driver's side? If so, you may have 62's on both sides.
#47
#48
OK, 62's are no slouches. If you can check one more thing, see attached. Does your engine have the pyramid projection behind the passengers side valve cover shown in the red circle of the attached?
#49
#50
The best way to know for sure what gears are in there is to pull the cover and see what's in there. Get the numbers off of the ring gear or count the teeth. You'll also know for sure if it's got a posi unit.
Sounds like a pretty good combo, Hope you can get it optimized. |
The Following User Says Thank You to F ROCK For This Useful Post: | ||
#51
The pyramid signifies a 428 or 455 block; 400's & 350's do not have it.
#52
#53
Sorry I missed this in post 36:
"So I got a chance to go through the things, car has matching 62 heads on it and is a 455. Are 62 heads worth having gone through (finding a machine shop to do it will also be a hassle around here) or just buy a set of 6x from nitemare performance for about 1500$" Still, its odd to find 62's on a 455. You need a piston dish better than 15cc maybe 20cc to make it streetable. Do you have problems with denotation, ping?
#54
#55
'62' heads should work well on this
On a 455 the compression will be pretty high, but it should make plenty of power.
MarkS57 asked about detonation. You said it detonated when you 'turned the timing up'. What initial and total timing do you have now and how much timing did you add to make it detonate? Sometimes, even when you can't hear it, the detonation is still going on. We've run several 455s at different times with flat-top pistons and '62' heads and always had to either mix fuel or run race fuel to get acceptable performance. The cylinder pressure was always too high for 91 or 93 octane pump fuel. But when we either mixed 110 octane with 93 octane - or even ran the 110 octane straight - they were tire shredders. Even with 3.08 gears. 3.55s just made it worse. I gotta believe that a good-running higher-compression 455 would still smoke the tires - even with 2.56s. Many guys have run the 72cc heads - like your 62 castings - on 455s with flat-top pistons and made it work well by using larger cams to bleed off cylinder pressure. I think you need to figure out what exactly is inside your engine and what parts are not working well together. I doubt that the '62' heads are the 'problem' part. Good luck! |
#56
#57
Take a compression reading, report back
A man who falls for everything stands for nothing. |
#58
I may be missing something but this head in not #62. Also, the head in lower pic sits on wrong side. |
#59
#60
Updated pics of the heads with both valve covers off while I repainted them and the intake and installing a smi carb
