Old 01-24-2011, 12:20 PM
wizard61 wizard61 is offline
Default Have these side moulding parts been reproduced yet?
I am hoping someone knows where to find parts for this type of side moulding. Has this been reproduced yet?
Thanks,
James
Name:	Side Moulding1.jpg
ID:	231982   Click image for larger version
Name:	Side Moulding2.jpg
Old 01-24-2011, 03:10 PM
steve v's Avatar
steve v steve v is offline
Those you have pictured are aftermarket moldings. The chrome part gets riveted to the body then the rubber insert was pressed into the channel.
I had rolls of that style rubber insert that I tossed out years ago, who knew anyone would be looking for it 20 years later? Your best bet is to check an old body shop's inventory.... they may have what you need.
Old 01-24-2011, 04:15 PM
Thanks for the reply Steve,
So this would have been a dealer installed option?
Thanks,
James
Old 01-24-2011, 04:25 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
my Formula had the same added molding as yours. Here is a source for it if you were looking for the replacement of what you have:
http://www.customautotrim.com/produc...ings/rivet.htm
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 01-24-2011, 05:13 PM
form74's Avatar
form74 form74 is offline
RicksGTO, thanks for the link, I planned on removing those when I get around to having the formula painted, but if their is a source for them.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 01-24-2011, 05:54 PM
Tunas73TA's Avatar
Tunas73TA Tunas73TA is offline
If you are planning on a repaint, I'd dump those things in a heartbeat.
We used to drill and pop rivet those things to all our new car inventory only to watch the rust bubble from under them
(and around the holes) a few years down the road.
That was in the 70's...
chuck...
1973 455 TA (07A)
Old 01-24-2011, 08:06 PM
Kell's Avatar
Kell Kell is offline
Thanks,
James
I certainly hope not
Old 01-24-2011, 08:12 PM
2manyT/A'S's Avatar
Not only that,but they are just PLAIN BUTT UGLY!
They totally destroy the side view/lines of the car. (makes it look like a Camero)
Old 01-24-2011, 08:27 PM
form74's Avatar
Well I didn't plan on putting them back on, so I guess their gone when the times comes.
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 01-24-2011, 08:41 PM
Norwood's Avatar
Norwood Norwood is online now
as they should be....
Old 01-24-2011, 08:58 PM
Well I'm glad I asked. To all who replied, Thanks. I have to agree that it does break up the view of the body quite a bit. I am in the process of rounding up some of the missing or worn trim items for my car before I begin its restoration. I'm glad I have one less issue to deal with now.
Regards,
James
Old 01-24-2011, 09:15 PM
Regards,
James
Excellent decision!
Old 01-25-2011, 12:09 AM
bird72's Avatar
bird72 bird72 is offline
after all that, should I tell him what I think of spoilers on Formula's?
72 Bird
Old 01-25-2011, 12:22 AM
2manyT/A'S's Avatar
Might ALSO be a good time to discuss Formula hoods with holes hacked in them for a shaker?
Old 01-25-2011, 12:40 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Ponch?
Corvette Summer???
ID:	232082   Click image for larger version
Old 01-25-2011, 10:12 AM
Kell's Avatar
Ah, you just can't beat 71 fenders with TA vents, a formula hood, shaker, spoilers, foilers, side pipes..., yep, that is pure class!
Old 01-25-2011, 10:15 AM
LeighP's Avatar
LeighP LeighP is offline
My friend is reproducing those side bump strips...correct styles and colours but in stick on rather than rivet on....I suppose you could rivet them on if you have a wish to destroy your car, lol.
He's been working on these for a while.....
try his website -
www.usgmsp.com
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 01-25-2011, 11:24 AM
bossbirdta's Avatar
CLASSIC!!!!
note: no body side moldings....
Old 01-25-2011, 12:31 PM
RicksGTO's Avatar
wow, seems like they could of fit a hood tach on there too...
Old 01-25-2011, 12:57 PM
Norwood's Avatar
And then take the tach out...it would be a mini shaker....
