Old 01-17-2011, 01:30 AM
Originally Posted by getmygoat View Post
The intake and head dates look good. I'm a moron and forgot to check the block date by the distributor. D-oh!
Anyway, the sequence number for the block is on the build sheet correct? That might be the next step. I assume its under the tank.
Nope. The EUN won't be on the buildsheet.
Would still be nice to find a buildsheet though.
The EUN would only be on the Billing History Card.
We don't have access to those these days for 1969 newer - just invoices.
We have observed two 1969 Billing History Cards in past years.
They were obtained from Pontiac - by owners who knew certain people back in the days before the free PMD invoices were available, and before PHS documentation became available.
=== DID YOU CHECK THE CARBURETOR NUMBER ? ===
  #82
Old 01-17-2011, 03:47 AM
getmygoat's Avatar
Default pics
Here are a couple more pics
ID:	231187   Click image for larger version
ID:	231188   Click image for larger version
ID:	231189   Click image for larger version
ID:	231190   Click image for larger version
  #83
Old 01-17-2011, 04:16 AM
getmygoat's Avatar
That's a bummer so there might not be a way to verify if the block is original. The car was owned by the grandfather for 5 years before being owned by the uncle - so its possible information about a warranty replacement was lost along the way
ID:	231195   Click image for larger version
  #84
Old 01-17-2011, 09:30 AM
gtojon gtojon is offline
With the sludge on that engine, I'd bet the farm on the original WS sitting there.
That is a nice car with a great story/history.
  #85
Old 01-17-2011, 11:19 AM
Bet Winner's Avatar
Bet Winner Bet Winner is offline
The dash pad has apparently been replaced since the GTO emblem is not there. The GTO emblem has been reproduced so it could be "corrected." Or might find a nice used emblem.
I assume that the parchment interior is called out on the data plate, but I would make sure. I would have assumed black, but some did get parchment. I have seen parchment more on the automatic pattern cars, but I have not seen a lot of them.
I assume that the VIN is there but cannot be seen with all the gunk on the engine. I'll try to see how high up mine is stamped today and let you know. You'll probably need to remove the hoses and clean quite a bit to see it.
This would be a great project or clean it up and drive it some. I forget if the engine has been rebuilt. If it has not and you start running the engine up some at wot, you'll be rebuilding it soon I'll bet. I got mine in 1979 and bored it .30 over in 1980 because it was fouling a plug....................................
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars."
Some people know all of their rights, but none of their obligations.
  #86
Old 01-17-2011, 11:24 AM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Originally Posted by Bet Winner View Post
The dash pad has apparently been replaced since the GTO emblem is not there. The GTO emblem has been reproduced so it could be "corrected." Or might find a nice used one.
Being a 1D Baltimore car, isn't that in the window that the dash emblem may have been deleted?
Have to pull back up past threads.
Found 1C Baltimore cars with the "GTO" dash emblem and 2A Baltimore cars without it. Anyone have a 1D Baltimore car??
P.O.S.I - It's not just a club...it's an addiction!
Last edited by 2manyponchos; 01-17-2011 at 11:31 AM. Reason: Looked at past threads...
  #87
Old 01-17-2011, 11:40 AM
getmygoat's Avatar
It doesn't show clearly in the pic, but I cleaned that flat spot down to metal. The VIN is not anywhere on that flat spot.
Owner has no knowledge of any prior rebuild. Was owner's aunt's daily driver until she became too sick to drive it - this was around the end of 2009. He says she never went over 40 on the highway - which sounds dangerous in so cal.
  #88
Old 01-17-2011, 12:01 PM
getmygoat's Avatar
Default rear end
Here are the pics I took of the rear end - unfortunately the codes are not as visible as I thought they'd be... The long # is clear - but I believe this is fairly generic. The date code is suppose to be above it - I thought this would be a code similar to a head code... A letter for a month, then two days, then the last digit of the year? But that's not what's there obviously.
Just for fun, I also attached a couple pics of the original spare time - its never been down, still has the little rubber nubs.
ID:	231212   Click image for larger version
ID:	231213   Click image for larger version
ID:	231214   Click image for larger version
  #89
Old 01-17-2011, 12:34 PM
Judge273's Avatar
Judge273 Judge273 is offline
Was it bought? If so, very cool!
Mike/Illinois
  #90
Old 01-17-2011, 09:50 PM
muscle_collector's Avatar
i have the one for my 69 orange ra4 bird.
  #91
Old 01-18-2011, 12:35 AM
richard sargent richard sargent is offline
PHS says 3.55 posi
  #92
Old 01-18-2011, 06:32 PM
robz's Avatar
robz robz is offline
Service bulletin dated Feb 24th/69 for Dash emblem delete...and my 2A also did not have it so....sounds about right, as they started removing them just before the SB...:-)
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
  #93
Old 01-19-2011, 12:47 AM
Bet Winner's Avatar
The date code is a julian date code I believe. The 9795084 casting number is right I believe, and the date will be the number of days into the year. 365 would be the 365th day of 1968. On the rear of the driver's side axle tube you should find the two letter code (XH if the posi hd rear I believe) and the assembly date of the rear close to the code. This assembly date code is in the same julian format. Here is a good thread to read--
http://forums.maxperformanceinc.com/...hlight=9795084
Now, a correctly dated tire is a real surprise!
Hopefully I was wrong about the GTO plate on the dash. Maybe Baltimore stopped using it the last half of January and this is the original dash pad.
  #94
Old 01-19-2011, 01:58 PM
My 2C Baltimore was built without either of the dash ornaments.
We had a thread 3-4 years ago that went into this subject about Baltimore dash ornaments and guys listed their examples. Can't remember if any 1D cars were mentioned w/o ornaments.
Back in days gone by, a lot of guys wouldn't get all the wiring back into all the loom sleeves and clip holders just right, when replacing a dash.
If you can get up under and spy behind the dash - if all wiring looks untouched and secured - probably original dash.
The key/door buzzer not working - is probably just a worn out buzzer dealio.
  #95
Old 01-19-2011, 02:01 PM
The Boss's Avatar
The Boss The Boss is offline
That or the owner just popped it out, cause he liked to sit there with the radio on and the door open enjoying his beer.....like I did.
And go racin' in the street.
  #96
Old 01-19-2011, 02:02 PM
The Boss's Avatar
Of course you do!
  #97
Old 01-20-2011, 11:43 PM
getmygoat's Avatar
Default Not a baltimore car after all
The car was built in Framingham, Mass. VIN is 242379G......
Does anyone have a 1969 Pontiac built in Framingham? Is there a VIN on the block?
  #98
Old 01-21-2011, 12:19 AM
Bet Winner's Avatar
If the ram air cable connector is original to this car, it will surprise a few of the national judges and me too. Good luck with the car.
  #99
Old 01-21-2011, 01:30 PM
Wasn't Framingham the factory that put the VIN in a non typical location? Like way up by the head or something like that?
Old 01-21-2011, 01:36 PM
robz's Avatar
Fremont did that...not sure if Framingham did as well...
1969 Grand Prix SJ
