#41
Just curious, as is my custom.
Some here are always nit-pickin about EXACTLY what the CR is. I always use the Wallace CR calculator, just because it's convenient, and because I don't know how to do all the math required to figure it myself. So, for you guys who know how to figure CR exactly, how far off is the Wallace calculator ? Can you put a percentage of error on it ? And exactly what numbers does that calculator fail to include, that determines CR ? http://www.wallaceracing.com/cr_test2.php For example: I've read that the volume of the area of piston-to-cyl-wall clearance, ABOVE the top ring, must be added in, as well as the volume of the portion of the head gasket bores, which are outside the base circle of that hole. So, aprox how much would the CR calculation be reduced by including these volumes ? |
#42
[QUOTE=Jay S;6053544]Thunderstorm alarm woke my up. So I will guess i will get to go first, lol
Crane compression ratio ranges are good for a 350 cid engine. Very accurate actually for a 350 cid engine. But not for the bigger 455. For the same compression the compressed volume is more on the 455 than the 350 (350 is about 24% smaller). Look at it this way, there is more volume in the cylinder for the overlap area of the cam on the bigger engine, 455 has more air to be diluted by the intake and exhaust mixture. It takes more overlap to effect the 455. Most cam mfg ratings are based on 350 cid, unless they say otherwise. Makes sense. I like Paul Spott's cam recommendations the way he breaks it down for both displacement and CR. |
#44
204/214 is a stock cam, smaller than some of the mild OEMs. If you want a stock cam, it is fine too.[/QUOTE] Well from all the responses and the way it's been explained to me, I won't use the 204/214 on this engine probably the 214-224. But as this is the largest engine I've ever had, I'm re-thinking cam choices. |
#45
Nice score on the 6x-8s. That will work great with the 214/224 cam. There are a lot of cam options at 9:1 in a 455 that are bigger than the 214/224 that still work good. Many of my daily driven vehicles in the past had either the 204/214 or the 214/224 cam, always served me well.
I don’t usually count the volume above the compression ring on an average street engine. I had a old speed pro piston for a 455 up next to a new speed pro piston and noticed they spread the ring pack apart more on the new piston and raise top ring fair amount. It wasn’t my engine so I did not check it, but FWIW, it looked like it could have changed the compression 1 or 2 cc’s. |
#46
HOWEVER Wouldn't hurt subtracting 1 or 2 cc's of SV for that. I used a set of KB pistons on another car that had the high location which required a wider top ring gap due to the extra heat expansion of the higher location. As for cam selection, I am now taking the larger displacement into account. I'm thinking the 214-224 in a 400 or 455 is similar to a 204-214 in a 326 or 350. Yup, that's why I'm here. Thanks for the advice. |
#47
I wouldn't bother with the above the ring volume. You might subtract a little swept volume for the KB high ring pistons but not sure it's enough to be of concern. What I don't have figured out is how to come up with dynamic compression ratio and how it relates to static compression ratio. I do know that cylinder pressure changes throughout the RPM spectrum, and different valvetrain/heads flow different for different RPM situations. What I think could be a total disaster is someone thinking that they can "cam away" too much compression which could result in higher RPM detonation. I'm thinking dynamic compression figures would protect against that, but it's not in my wheelhouse yet so for now I'll just use common sense. |
#48
Aren't the #66 valves shorter than the 6X valves?
This is going to save me a lot of money, thanks for the good advice. |
#50
The factory put the fairly long duration ‘323’ cam in the low-compression (8.4:1) 455 SD engines, about 224 intake and 230 exhaust at .050”. They originally wanted to use the ‘041’ RAIV cam (231/240 at .050”) but it wouldn’t pass emissions testing. These cars left the factory with a 3.42 gear most of the time in auto trans form if I’m not mistaken.
You might be surprised at how much cam you can put in a low-compression 455 and still maintain good street manners. I used to bracket race a low-compression (8.6:1) 455 running the H-O Racing HC-02 cam (244/252 at .050”) in a fairly light weight (3330# w/o driver) car. That cam required the use of a good 10” 3400 stall converter and a low rear end gear to get any decent performance out of it, I was using a 3.89 gear and 28” tall slicks. Probably a bit too much gear but it’s what I had and it worked fine for racing in the brackets. Use a mild cam such as the 214/224 if you’re going to use a tall highway gear (3.08, 2.73 or 2.56) and a stock converter. Step up to a bigger 224/234 if you go for a little more gear such as a 3.23 and maybe a 2500 converter. For more serious performance go even further with a 230/240 cam and a 3.42 or 3.55 gear. Nothing hard and fast here, just some general guidelines. A 455 will pull a very tall (low numerical) gear and still perform amazingly, some very hard running street 455s have dipped into the 10s in the 1/4 mile using 3.08 to 3.42 years. All of these different cams mentioned will work in a street 455 with 9:1 compression or less. The longer duration cams will be better optimized when used with higher compression ratios but that doesn’t mean they won’t run and run strong in low compression 455s. My bracket race 8.6:1 455 was built using what I had laying around in my garage. It was not a perfectly optimized engine combo but that didn’t stop it from being a very competitive car that was fun to drive and performed well, running in the 12.0s at over 110 mph.
#51
You’re best off going to a stainless steel one piece valve anyway, the factory 2-piece units (friction welded head to stem) are known for coming apart and destroying engines. Your 455 will thank you, they’re not making them anymore.
#52
My #66 head"s valves measure 4.86" intake and 4.847" exhaust on average. Not sure if the stems have ever been re-faced or if the valves have been replaced; the engine had been rebuilt.
Wallace racing is showing the 6X-8 valves as being 4.86" both intake and exhaust. So the 66's exhaust valves are approximately .040" shorter in this case. I'm thinking after the valves are seated, measure the retainer height and see how close I am. Order springs to give me close to the right pressures, maybe remove the metal umbrellas to help add .020 assembled height if needed, shim the intake side if needed. IF I had to I could try some off-set keepers. I also want to use the rockers, pushrods and guide-plates that came with the 66's as long as the rockers contact the valves close to center, if they don't I'll get a pushrod checker. I already used the 66's valves to check the guides on the 6X-8 heads, they are surprisingly tight. Would a new set of 4.970" valves be too long ? I appreciate your input. Do you think is this a plausible plan? |
#53
Wallace racing is showing the 6X-8 valves as being 4.86" both intake and exhaust. So the 66's exhaust valves are approximately .040" shorter in this case. I'm thinking after the valves are seated, measure the retainer height and see how close I am. Order springs to give me close to the right pressures, maybe remove the metal umbrellas to help add .020 assembled height if needed, shim the intake side if needed. IF I had to I could try some off-set keepers. I also want to use the rockers, pushrods and guide-plates that came with the 66's as long as the rockers contact the valves close to center, if they don't I'll get a pushrod checker. I already used the 66's valves to check the guides on the 6X-8 heads, they are surprisingly tight. Would 4.980" valves be too long? I'm capable of installing longer push-rods if needed and I have not ordered needed rocker studs or valve springs. I appreciate your input. Do you think is this a plausible plan? |
#54
What your plans are for the 455 are starting to resemble a 455 budget build we did for a friend years back. Started with a used 455 short block. We honed it, reused the cast pistons, gave it new rings and bearings, rods received arp rod bolts. 60 psi oil pump. It had the rods resized, mains and crank were checked, and the crank polished. No other machine work on the short block. We used 6X-8 heads, I ported them, mostly the valve pockets and removed the places Steve25 mentioned. I ground and reused the stock valves, kept the 1.66 valves in it. On our flow bench it flowed mid 230s cfm on the intake, and around 10% gains on the exhaust. It had a melling Ram air 4 cam with 1.5s, q jet, stock intake with log manifolds. Went in a 70 GTO with 3.23s. Ran decent, i think it would have ran better with less cam, more in the 224/234 range. But with an open rear end it had no issues lighting up the back wheel. If the 66 heads have some newer 1 piece stainless valve installed I would reuse them, but, FWIW, being budget oriented, if I was given a choice, used valves and pay for the machining to install 1.77 exh valves. Or just new valves and retain the 1.66 exh valves. I would spend the $170 and do the new ferrea 4.98” valves and run 1.66s. Used 2 piece valve are not worth using when new 1 piece are reasonably priced. The carnage from a broken two piece valve is not pretty either... Last edited by Jay S; 10-01-2019 at 11:03 PM. Reason: Error |
