Old 11-02-2020, 10:45 AM
My65GTO My65GTO is offline
Default Alternator puts out 16VDC
SOS! 65 GTO having charging issues. Alternator is putting out 16VDC to the battery. The regulator smokes out the back. Have changed the regulator with 2 others, same issue. Had the alt and reg bench checked and all are ok. Changed the engine harness, added a third ground wire.
Going to try another alt tomorrow.
What else could cause this?
George
Love 'em Everyday!
G-Man
Old 11-02-2020, 11:16 AM
george kujanski's Avatar
regulator or wiring issue. it' the reg's job to control the output voltage. "added a third ground wire"....where? BTW the reg body needs to be mounted with a good electrical ground. Try connecting a jumper wire from the reg metal body to the batter negative.
George
Old 11-02-2020, 12:30 PM
Check for battery voltage on terminal #3 of the regulator.
If it doesn't have full battery volts, the regulator will think the battery is weak or dead and make the alternator over charge.
Clay
Old 11-02-2020, 03:19 PM
stellar stellar is offline
All of the above and also a bad battery. New mechanical regulators will smoke when new for a short time. The resistors get hot and this is normal After initial burn off it should not continue to smoke.
Old 11-03-2020, 02:35 AM
Geoff Geoff is offline
Make sure there is a grd strap from the f'wall to the engine [ bell housing bolt is a good place ].
