1971-72 GTO PARTS
1972 GTO Accelerator pedal & bracket, throttle cable hard to come by $225.00
1971-72 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00 1971-72 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00 1070-72 AM &FM RADIO $475.00 1969-72 AM RADIO WORKS $200.00 NOS A/C Delco PVC $9.00, NOS PULLEY 481040 still in GM BOX $100.00 NOS A/C Delco oil Filters PF 24 $11.00 each NOS Three prong Thermo Switch for rally gauges $250.00 NOS 1970-72 Wheel well moldings $850.00 1970-72 pair of used rear Wheel molding $200.00 1971-72 GTO FRONT ENDURA BUMPERS WITH FRAME TO BUMPER BRACKETS AND CENTER SUPPORT BRACKET $500.00, 1971-72 GTO FRONT ENDURA BUMPER WITH NO BRACKETS $300.00 1972 GTO GRILLS $300.00 1971-72 GTO HEADLIGHT HOUSING ASSEMBLIES PR. $350.00 1971-72 GTO ENDURA BUMPER TO FRAME BRACKETS $150.00, 1971-72 GTO HEADLIGHT ASSEMBLY HOUSING BRACKETS $100.00 1971-72 GTO FRONT CENTER SUPPORT BRACKET $125.00 1971-72 GTO COMPLETE HOOD LATCH ASSEMBLY TO CORE SUPPORT BRACKET $250.00 1971-72 power brake booster $50.00 1971-72 GTO/Lemans lower main duct and vents $125.00 1971-72 Intermediate steering shafts $50.00 1971-72 Rear Windshields $80.00 1971-72 Coils $25.00 1971-72 Oil Filter housings $85.00 each 1971-72 front lower window reveal molding $60.00 1971-72 rear front upper fender chrome moldings $30.00 pr. 1971 Throttle cable $45.00 1971-72 Turbo 400 Transmission oil pans $50.00 1971-72 door vents pr. $20.00 1971-72 positive battery to starter heat shield tube, 1971-72 window regulators set of 4 $150.00 1971-72 brake pedal & bracket assembly $100.00 1971-72 emergency brake pedal and bracket $75.00 1971-72 rear license plate bracket and holder $35.00, 1971-72 water thermostat housings $20.00 , 1971-72 door hinges $50.00 1968-74 points distributors $80.00 1971-72 wiper transmission assembly (2) $75.00 1971-72 blower motors $25.00 1971-72 a/c inner boxes $150.00, 1971-72 headliner bows $50.00 set Hurst Dual Gate Shifterr Restored Correct for 1968 will work in 71-72 $525.00 1969-75 Harmonic balancer $50.00 11 Bolt Timing Cover $105.00 11 Bolt Timing Cover withy divider plate and pump $150.00 Full length windage trays $80.00 1971-72 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00 1971 GTO Rear Taillight lenses $125.00 Each 1970-1972 Rear Taillight housings $75.00 Each 1972 Purge valve hard to come by $175.00 1972 Pewter grey door pull straps $80.00 1971-74 alternator bracket for non p/s $50.00 1969-72 Goldenrod/Tan steering wheel crack free $125.00 1969-72 auto shifters $135.00 Fuel escentrics $35.00 1969-72 harmonic balancer off low mileage car $50.00, flexplates $35.00 1970-72 inside glove box liner $45.00 1969-72 Gauge & Speedometer cluster $65.00 1970-72 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00 assorted stainless moldings, 1971-72 miscellaneous duct work 1970-72 driver side lower dash trim $50.00 1969-72 radio rear support bracket $25.00 1968-72 Tag light & bracket $15.00 Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00 1970-72 door glass $100.00 used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley, 480509 TCS Switch $75.00 1970-72 pillar post covers $45.00 1971-74 New Power Steering Pump $90.00 1971-79 used power steering pump $45.00 1971-77 Alternator bracket $50.00 1971-72 front fender side markers lenes,frames and bracket clips $90.00 without frame brackets $50.00 1971-72 GTO headlight & parking light wiring harness $75.00 1971-72 Engine wiring harness for 400 with auto and ac $50.00 BLUE VALVE COVER OIL CAP $25.00 VERY NICE NON A/C HEATER HOSE BRACKET $25.00 Pontiac oil pan $65.00 1972 front parking bezel $30.00 1971-72 ALTERNATOR/POWER STEERING BRACKET $50.00 1973-74 ERG Valve and Bracket $35.00 new points and condensers __________________ Timmy Mallory Email me at temallory@msn.com __________________ Timmy Mallory
Timmy Mallory |
am&fm radio has been I sold! I have one am radio left for 69-72
Timmy Mallory |
wiper transmissions have been sold!
Timmy Mallory |
fender front marker lights
Hi Tim Can you send me pictures of the front marker lights. 323 6036943 Enrique Thank you
Thread Tools | |
Display Modes | |
