Tri-Power Tech 57-66 Tri-Power Talk
Old 10-31-2020, 08:23 PM
lucky1 lucky1 is offline
Default PCV vacuum ?...
Anyone know why there are two vacuum connections on the 65-66 tri power
Manifolds For the PCV hose instead of just one. .?..
Also would you lose PCV efficiency if you only used one of the two nipples and
Capped the other ??
Thanks as always.
Old 11-01-2020, 06:07 AM
Kenth's Avatar
Kenth Kenth is offline
They distribute the crankcase gases to both planes inside the intake for all cylinders to burn the gases.
You can get the correct tee at Ames.
The brake booster hose/tube/nipple is connected at rear of front carb.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-01-2020, 04:05 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
It’s not just the Tri-Power intake manifold.
Same design for the 4BBL. intake manifold.
Chris.
ID:	552870   Click image for larger version
Old 11-01-2020, 08:00 PM
Default Thank you.
Thank you.
Old 11-16-2020, 08:15 PM
Tom Vaught's Avatar
Boost Engineer
I know this is the Tri-Power forum but some 4 BBL info for you as related to the PCV system.
The later 4 bbl intakes have a single inlet (Hose) connection to the intake but the fitting is actually designed (if you remove one of them) so that vapors (CFM) from the PCV Valve is directed to both planes of the 4 bbl intake.
It threads into the upper intake plane but feeds both the upper and lower intake planes with fumes from the crankcase area or thru the Valve cover in a few engines.
Tom V.
