Tri-Power Tech 57-66 Tri-Power Talk
Old 11-15-2020, 02:32 PM
Dick Boneske's Avatar
Default Hot Idle Compensator
Did all the '65 automatic Tri-Powers use the center carb with the hot idle compensator in the back? I know all the '61-'64 Tri-Powers with automatic transmissions did have it. I've attached some pictures to show what I'm referring to. The hot idle compensator is under the steel cover secured by two screws an the backside of the carb.
I believe all '66 center carbs used this, manual or automatic, but it was located inside the venturi cluster area instead of on the backside as in the picture.
ID:	553938   Click image for larger version
ID:	553939   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 11-15-2020, 04:06 PM
Kenth's Avatar
Kenth Kenth is offline
Yes, according to the Delco Rochester bulletins they did.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
