#2061
Thanks. When you get the tuneup fully dialed in. How much boost will you be able to run?
Stan
#2062
Not sure at this point when additional boost won't make more power. We still have timing to play with too.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#2063
to small to read
#2064
Picked up some 91mm turbos and wastegates from Rodney Butler. Possible addition sometime in the 2024 season.
Comparison based on timeslips and http://www.wallaceracing.com/Calculators.htm racing calculator. Raven 1/4 Mile 7.34 @ 194.32 3650lb Your HP computed from your vehicle ET is 1,637.63 rear wheel HP and 1,819.59 flywheel HP. Your HP computed from your vehicle MPH is 1,881.22 rear wheel HP and 2,090.25 flywheel HP. Rodney Butler 6.278 @228.11 2720lb Your HP computed from your vehicle ET is 1,950.37 rear wheel HP and 2,167.07 flywheel HP. Your HP computed from your vehicle MPH is 2,267.76 rear wheel HP and 2,519.73 flywheel HP.
The Following 2 Users Say Thank You to RAIV-Z For This Useful Post: | ||
Thread Tools | |
Display Modes | |
