Looking for a running quadrajet for 400 c i
I am looking for a quadrajet so I can get out of this Holley funk.
something for a 68-71 400 automatic 325 horsepower. I need one that will be able to put on and go. Not worried about numbers matching. Thanks Greg |
pm sent
I have a nice one from a 71 Pontiac
Sent from my XT1710-02 using Tapatalk
Chris Collier 1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans "There is no such thing as too much horsepower" |
Still need one? I have one that was most recently on a 67 400. It is not an original 67, though.
Jeff Ianitello |
Some Q-jet builders occasionally have a few in stock, ready to go. Most of the '71- up Pontiac Q-jets have the big "smokestack" vent, which requires a special hole in your air cleaner base. If you want a '71-up model, with a front inlet, but without the big vent, you can buy an Olds or Buick model. Cliff mentioned in his book that the early '70's 800cfm Buick models make good carbs. He also likes the '76-'79 800cfm GM models, because they have the APT feature. May have to modify the throttle cable hook-up, on a later model, or different brand.
https://quadrajetpower.com/ https://www.smicarburetor.com/produc...D2/9/sfID3/100 http://www.everyday-performance.com/...arburetors.htm Everyday has this '68 750cfm Buick model for sale. Listed for $450, as I'm posting this. http://www.everyday-performance.com/...ategory=578011 Cliff has mentioned that he is beginning to wind his rebuilding business down. So, I assume he probably don't just build one for resale, but rather rebuilds customer carbs. But, I obviously can't speak for him. Then there are always the Ebay Q-jets, if you wanna take a chance on one of 'em. https://www.ebay.com/itm/1969-OLDSMO...YAAOSwj9xdg-hV Last edited by ponyakr; 10-29-2019 at 12:38 PM. |
I want to thank every body for their replys I have a couple located. I am considering a tri power but that remains to be seen.
Thanks |
