Old 10-13-2019, 11:04 PM
PurelyGTO68 PurelyGTO68 is offline
Default 1968 disk brake hose brackets
I am looking for the brackets for 1968 disk brake hoses. These bolt to the caliper mounting brackets with two little bolts. The replacements I ordered from Ames are completely different than my original style. I believe I have the LH bracket but need the RH one. I will purchase a pair if you dont want to break up the set.
Possibly the last items I need to take the car on its maiden test drive.
Let leave know if you have something for sale.
I could also use the 4 little bolts if you have them as well.
Old 10-13-2019, 11:54 PM
GTM GTM is offline
Send a message via Yahoo to GTM
I think Inline Tube has the correct brackets. I had the same problem, I only had one bracket. I made one from the original and it worked well
Old 10-14-2019, 09:12 PM
I checked with Inline Tube. They just have the other style brackets same as Ames. The hunt continues....
Old 10-14-2019, 10:14 PM
GTM GTM is offline
Are you talking about the two pictured, of the one in the back? The two pictured, I've seen at I.T.
Old 10-21-2019, 12:39 AM
68pongto's Avatar
68pongto 68pongto is offline
The brackets you need are the same as the ones used on drum brakes.
Old 10-21-2019, 12:59 AM
68pongto's Avatar
Here are some pictures of the brackets on an old drum brake setup.
Old 10-21-2019, 06:00 AM
trynsave trynsave is offline
pm sent
Old 10-21-2019, 09:55 AM
68pongto's Avatar
I went and checked all my old drum brake setups, I have a bunch of them. Let me know if you still have trouble locating one.
Old 10-30-2019, 04:39 PM
Attachment 522576
Thank you. This helps a ton! I found what I need at the local salvage yard from a drum brake car.
For some reason, I never was notified of all the replies so apologies for the late response. I pulled up this thread to say that I looked in the MPC book and it said drum and disk used the same brackets in 68. I then see all the helpful responses that I missed earlier
Thanks again guys for the help. Very much appreciated.
Thread Tools
Display Modes
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
