Old 10-22-2019, 09:31 PM
ddcrank ddcrank is offline
Default 68 Gto drive shaft markings
I have a 68 GTO conv. std engine. Automatic. And im looking for help on the drive shaft markings. Any pictures and measurements of where the strips go around the drive shaft and what color they should be for my application would be of help.
Old 10-22-2019, 10:14 PM
68pongto's Avatar
68pongto 68pongto is offline
According to the service manual, many build sheets I have and original driveshaft I have seen, the colors are one red band and two white bands. If you look closely on you driveshaft you can usually find faint marks where the original stripes were.
Old 10-22-2019, 10:32 PM
OG68 OG68 is offline
One Red, Two white bands.
The attached photos are of my 3 Spd Dearborn. Measured from the front u-joint.
Yours may be different since it has three bands
ID:	522696   Click image for larger version
ID:	522697   Click image for larger version
ID:	522698   Click image for larger version
2007 Cadillac SRX
Old 10-23-2019, 12:14 AM
kk68's Avatar
kk68 kk68 is offline
Here’s a pic of the faint markings I found on my driveshaft and one after repainted. Three ~1” bands located approximate middle of shaft, from front to rear, red, white, white. This is on a std 400 automatic GTO.
ID:	522704   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 10-23-2019, 04:19 AM
Thanks guys that was exactly what I needed. Is it safe to say that the bands didn't all start or end in the same spot on the drive shaft? That it was a random thing where the first band starts and the last band ends ?
Old 10-23-2019, 08:01 AM
Brewster's Avatar
Brewster Brewster is offline
Ive seen the locations of bands were consistent. The grouping and colors changes depending upon year and application.
