Old 11-09-2019, 05:42 PM
beertracker's Avatar
beertracker beertracker is offline
Default 455 Main Bore Diameters
Could someone tell me what the main bore housing diameter for a 455 should be? Mine measure 3.4264-3.4268 without bearings installed and caps torqued. I am using a telescoping gauge and calibrated .0001" mic for measurements.
The crank main journals have been cut .010".
Old 11-09-2019, 05:59 PM
llwta76 llwta76 is offline
3.4380-3.4390 is the range. Trying to hold the main housing bores near the middle of that range is best. Larry
Old 11-09-2019, 06:09 PM
Bill Hanlon's Avatar
Then how did beertracker's get smaller?
Old 11-09-2019, 06:29 PM
I'd say he needs to remeasure it?
This is the block measurement without the bearings in the bore correct?
Old 11-09-2019, 08:36 PM
The numbers in above quote are without main bearings and the caps are torqued, right? My numbers in the first post are smaller than these. I will recheck my numbers. Maybe I mis-read the mic? If I did I am consistently wrong five times.
Old 11-09-2019, 11:20 PM
I re-measured #1 main housing bore (no bearing installed, cap torqued) and the number was the same. So I am reading the mic correctly and the number is too small. I paid the shop to run a align bore test and they told me my block does not need a align bore so none was performed. Apparently my shop did not not check the main bore housing diameter. I supppose that is extra money for that service?
Does anyone have any solutions beside having the main housing bores re-bored to spec? I suppose that is called a align bore job? The other solution is to quit while I am ahead.
Old 11-09-2019, 11:35 PM
AG's Avatar
AG AG is offline
You need to get a dial bore gauge.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-10-2019, 12:07 AM
This ^. Or take it to ANOTHER shop to check while you wait. ( I wouldn't go back to them for any work )
Your readings are over .011" too small
Old 11-10-2019, 02:21 AM
chiphead's Avatar
chiphead chiphead is offline
Did you use a telescoping snap gauge? Not nearly accurate enough for measuring a precision hole down to .001. You need a dial bore gauge with a dial readout. Even a cheap Fowler with a .0005" dial would be OK.
.011" too small is a gigantic, unimaginable undersize. No way a crank would rotate with housings that small. It's got to be a measurement error??
The correct machining procedure would be a line hone to correct slightly under/oversized crank tunnel with original caps. Line bore is a more involved and aggressive process for fitting replacement caps. Do you know if the caps are original to this block?
Old 11-10-2019, 07:40 AM
steve25 steve25 is offline
The your motor has the same main Bore size as the 421 listed here.
The first shot list Bearing clearance ranges for street motors, and the second shot for race.
This info posted was out of the Federal Mogal Bearing book.
ID:	524151   Click image for larger version
ID:	524152   Click image for larger version
Old 11-10-2019, 10:44 AM
Originally Posted by beertracker View Post
I am using a telescoping gauge.
Ends on this guage flat or round?
Are you seeing any difference between up down measurement and parting line measurement?
Does parting line have a lip or stair step that you can feel?
Buffalo Springfield "For What It's Worth"
There's something happening here
What it is ain't exactly clear
Clay
Old 11-10-2019, 10:47 AM
Yes, I am using a telescoping snap gauge and calibrated .0001 resolution mic. Strange thing is I asked the same question over on PSP forum and never got a answer. I don't know if the caps are original to the block. bt
Old 11-10-2019, 11:01 AM
Thank you for the info. bt
Old 11-10-2019, 11:32 AM
Talking
Clay
Snap gauge ends are rounded.
All measurements were taken at 12:00 and 6:00 positions. Will check 9:00 and 3:00 positions.
No lip or stair step felt or gap at parting line.
Agree with Buffalo Springfield
Old 11-10-2019, 03:27 PM
Most times when the main caps are not original to the block the main saddle is actually larger than spec, not .011 too tight. At this point, you’d be better off to take the block back to the original shop and have them mic the main saddle with you present. Take a Sharpie and write each measurement on the pan rail.
Dr. Thomas Sowell
Old 11-10-2019, 06:31 PM
Thumbs up
Good idea, thanks, bt
Old 11-10-2019, 10:04 PM
Half-Inch Stud's Avatar
Measure at 70F, two mesurements where 1 measure is 90 degrees from the other.
Old 11-13-2019, 06:51 PM
Problem solved I was mis-reading the mic. I was one decimal place off. Thank to all who helped. bt
