Old 10-02-2022, 02:24 PM
supersport#69 supersport#69 is offline
Default 68 dash knob help
I’m having trouble removing wiper knob bezel and cig lighter container insert.
What’s the trick?
Old 10-02-2022, 03:48 PM
uput you hand behind the dash to the switch, and rotate that back-n-forth, while using a small screwdriver to keep the slotted ferrule.
Make a slotted ferrule tool from a 3/8 (or so) steel line.
Old 10-02-2022, 09:12 PM
I ended up figuring it out.
My knob kit came with a lighter bezel. However the bezel doesn’t make sense though unless the lighter container is wrong in there. I don’t see how I’d use it.
Old 10-03-2022, 10:11 PM
OG68 OG68 is offline
68 A & B models used a soft aluminum ferrule around the lighter. Not reproduced and comes up occasionally on ebay.
The "LIGHTER" bezel included in the kits are for 69-72 A bodies
2007 Cadillac SRX
Old 10-03-2022, 11:59 PM
Oh ok. So my lighter is correct then.
Old 10-04-2022, 09:30 AM
Aluminum ring was a "theory" to spread the Heat better.
....yet we all use the "Lighter" bezel, and toss the plain aluminum bezel. A matter of taste you know.
Old 10-04-2022, 03:04 PM
I actually didn’t even notice a difference until I realized I didn’t know how to use that bezel in the kit.
Old 10-04-2022, 09:25 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Pretty sure the lighter bezel thing has been covered before and it is determined by which lighter you have, rochester or casco.
Leo
