Old 10-19-2020, 09:05 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Default 69 gto fender gap
Have this thing finally lined up and body worked, how does the fender to bumper gap look? I have a little less then ⅛ inch gap, don't want any paint rubbing! What is the factory gap set at?
ID:	551806   Click image for larger version
ID:	551807   Click image for larger version
ID:	551808   Click image for larger version
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 10-19-2020, 10:13 PM
Looks nice! I think the factory hood to fender gap is the same as the deck lid to quarter panel gap, plus or minus 1/32
Old 10-20-2020, 08:15 AM
Looks good here..I wish mine fit that well.
Old 10-20-2020, 09:05 AM
n20ta2's Avatar
Yeah it took some work to get it like that. I know the factory didn't get it that nice. Im more concerned with the fender to bumper gap. I know if its to tight paint will chip off from contact, I currently have ⅛ gap there. I have around 3/16 -1/4 for the hood to bumper and I'm happy with that.
Old 10-20-2020, 10:44 AM
dataway's Avatar
dataway dataway is offline
Definitely better than factory. After you get it painted you can test it by jacking up the car real high with bumper adapter
To be honest, I'd probably want just a tad more, those bumpers jiggle around quite a bit on bumps. That's one of the best fit-ups I've seen, would be a shame if it cracked the paint.
Old 10-20-2020, 12:03 PM
n20ta2's Avatar
Thanks!, lol on the bumper jack! I filled that with 3m flexible parts epoxy so no one would be tempted to try that. I guess its ready then, glad that part is over. I think the only thing that was harder was getting the fender to door gap perfect, what a pain!!
Old 10-25-2020, 09:00 AM
roger1's Avatar
roger1 roger1 is offline
Looks like you nailed it to me.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
Old 10-25-2020, 11:12 AM
cnc's Avatar
cnc cnc is offline
Man that looks awesome can't wait to see some paint on it...
U said u used 3m flexible parts epoxy ...uhave a part number by any chance or pic too....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-25-2020, 07:14 PM
n20ta2's Avatar
05895a 05895b 2 part epoxy sands easily and flex rate is identical to endura.
Old 10-26-2020, 08:01 AM
Not trying to undercut you here but just for your information, the Southern Polyurethane epoxy primer has been hailed to the heavens around here as the absolute 'go to' epoxy for endura. It was too late for me and I'm seeing a little cracking now on mine.
Old 10-26-2020, 09:05 AM
Just FYI-
Please read these posts from the same thread-
https://forums.maxperformanceinc.com...71&postcount=2
https://forums.maxperformanceinc.com...9&postcount=10
Old 10-26-2020, 06:09 PM
n20ta2's Avatar
I'm using the spi epoxy primer, the 3m part number I gave him is for a 2 part epoxy for repairing or building up the bumper.
Old 10-26-2020, 06:31 PM
n20ta2's Avatar
This is the 3m repair
Old 10-27-2020, 07:44 AM
Cool. I wish I had a good spare. I'd really like to re-do mine but I ain't going there at this point. If I had a spare, I'd do that one and swap it.
Old 10-27-2020, 12:42 PM
cnc's Avatar
cnc cnc is offline
Great thanks
Old 10-27-2020, 01:13 PM
mrennie's Avatar
mrennie mrennie is offline
Some additional info on epoxy repair products:
http://forums.maxperformanceinc.com/...02&postcount=2
Since that post, I also tried a Canadian product from Dominion Sure Seal, Flexible Epoxy Repair XPST.
https://www.dominionsureseal.com/pro...approved-xpst/
It comes in 2 large squeeze tubes, and mixes to a nice bright blue. It sanded nice but I found it a bit slow to set up and easy to scratch with a fingernail even after being cured for a week. Perhaps the product I bought was old...once the SPI epoxy was sprayed over top, all was good.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 10-27-2020, 05:44 PM
n20ta2's Avatar
I'm extremely pleased with the 3m, it sets up quickly sands easily and seems extremely durable. These tubes are large at 5oz each and were I believe around 50 bucks.
Old 10-28-2020, 07:58 AM
For bumper repair, I actually used the off the shelf 3m 806 epoxy and it worked perfectly. Looked and felt exactly like the raw endura and totally invisible after sanding. I think it's marketed under the Bondo brand now.
Old 10-28-2020, 08:18 AM
n20ta2's Avatar
I have some of that too, I think its the same stuff just in smaller tubes. I mixed batches of each and it was identical, I think 3m must make it for them lol. I would have used a bunch of those tubes so the 3m product was cheaper for me.
Old 10-28-2020, 08:28 AM
Yeah, I would bet that they are the same thing also. I had to buy at least two of those packages in the small size. I didn't need a ton of work to the endura itself. Most of my work was having to straighten it and a few gouges here and there as a result and some old damage that was already there. Amazing stuff. Exactly like the endura material when sanded. Dries quickly and sands very easily also.
