Old 05-07-2024, 02:42 PM
balmfort's Avatar
balmfort balmfort is offline
Default ISO harmonic balancer for 1963 389
ISO harmonic balancer for 1963 389 w/AC (not sure what years are compatible for '63). Mine has broken, not sure condition of crank until I tear it down. dont need the pulleys, only balancer that mounts to the crank.
Need crank bolt as well
Name:	2024-05-07 13.59.51.jpg
ID:	633373   Click image for larger version
Name:	2024-05-07 13.52.26.jpg
Phil
'63 Grand Prix / 389 Tri-power
Old 05-07-2024, 02:53 PM
tom s tom s is offline
I think I have one,not sure about the bolt.Tom
Old 05-07-2024, 03:02 PM
PM sent.
Old 05-07-2024, 03:04 PM
That is the hub,I have it with the balancer bolted to it but no pulleys.Tom
Old 05-07-2024, 03:11 PM
balmfort's Avatar
I only need the hub, all other parts (expect bolt) are okay. not sure of condition of crank until I tear it down
Phil
Old 05-17-2024, 08:26 PM
balmfort's Avatar
Update on my balancer failure. I purchased a replacement hub and crankshaft bolt. The bolt wont tighten to specs. So it looks like I have to pull the motor and get a replacement crankshaft. Anyone know if the crank bolt hole can be machined to accept a larger bolt? any other ideas. Will be pulling the motor out once I get the accessory drives out and trans disconnect. Wont be cruising for a while ;-(
Phil
Old 05-17-2024, 10:09 PM
Get a shorter bolt!Tom
Old 05-18-2024, 09:40 AM
694.1 694.1 is offline
Sounds pretty un fun. I would think a thread insert would work.
Or there are some cranks on this side of the pond, I will ask around.
Still have my 1st Firebird
7th Firebird
57 Starchief
