Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Closed Thread |
#101
7 get new nuts (I'm assuming they were stretching, at that time I couldn't find a better grade stud). So I changed to ARP 12 pointed nuts but with the larger 11/16" head for more thread engagement to help, so when I found a better stud I changed. I will have pics on the nuts later today. GTO George |
#102
The 2 nuts I’m using (on the right) on my head studs and the old 8740 nut!
GTO George |
#103
Well I’m still waiting on my head gaskets I decided to rewire the front (engine compartment) of the car.......I hate it! I’m just not that type of guy but since I’m adding my fuel level sender gauge I figured it was time well spent!
GTO George |
#104
Well I got my engine in Friday but still no head gasket, they are coming Monday. Before I bolted up convertor to flywheel I had to grind the heads of the (3) - 1/2” grade 9 bolts.....pain in the butt. Clearance between engine diaper and flywheel is almost non-existent, so I need to thin the head of the bolts down.
GTO George |
#105
Who made that timing cover? Thanks George.
#106
KRE........it use a sb Chevy water pump.
GTO George |
#107
Stan
#108
That’s a good question! I normally just hit them with my cordless 1/2” impact with blue loctite. I tried looking for the torque numbers for them but couldn’t find it, so I just did the above again. I’ve never had a problem, just wanted to torque them this time.
GTO George |
#109
Grade 9 bolts are good for 180,000 tensile strength same as standard ARP 8740 bolts.
GTO George |
#110
Usual torque is about 35-40 lb ft.
#111
Wouldn’t it matter what size the bolts are?
GTO George |
#112
I show that for a grade 2 (1/2") and around 90 for a grade 8 (1/2"). Chart doesn't have grade 9
Stan
#113
Actually i think mine would be torque to about 80 lbs. with my impact and 6" extension. GTO George |
#114
I sent my carbs to APD to get redone so they can flow more fuel, I'm getting them back tomorrow. I also just ordered new jets for them 218 & 226.....talk about BIG! I have 212 jets in the carbs now.
GTO George |
#115
I use grade 8 and 90 sounds about right. FWIW, I would be a little concerned about grinding the heads of the bolts, George. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#116
GTO George |
#117
GTO George |
#118
It's the grinding that bothers me, not the thickness----heat, loss of strength, etc. Jim
#119
I'm not getting the picture George. How could an engine diaper be near the head of a flywheel bolt?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#120
"Wouldn’t it matter what size the bolts are?"
Yes, the specs I gave are factory torque/bolt sizes |
Closed Thread |
