Old 04-19-2020, 08:15 PM
David Jones's Avatar
Default Power Window Switch
My 69 GTO has power windows. I have a love/hate relationship with them, with wishing they were of the Armstrong roll up variety winning out more often than not.
But.....
Is it possible to repair a power window switch?
They appear to be crimped together, I’m wondering if there is anything in there that can be adjusted or tightened or cleaned or whatever if I went through the trouble to take it apart? The passenger side switch will get the window down but not up. The driver switch gets the 3 other windows but doesn’t work the passenger window. I’ve tried aftermarket replacements without much luck.
Old 04-19-2020, 08:26 PM
Scott Thelander's Avatar
can you jump the plug on the backs of the switch with the switch off and make em work ?
and yes only flatten out 2 of the tabs enuf to slide the 1 switch style apart....
are the intermittant also???
I find 1/2 the time its a broken wire in the door jamb....
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 04-20-2020, 07:08 AM
On the driver side, I’ve done nothing, just confirmed lack of passenger side operation with the 4 way driver switch. On the passenger side, I’ve run power around the switch and the motor runs the window up and down. Possibly I should run power directly to the switch and check it’s operation that way before I take the switch apart or is the fact that it lowers the window good enough to confirm power is there and the switch needs attention?
Old 04-20-2020, 12:31 PM
After staring at one of the OEM passenger switches on the workbench, I decided I’d take it apart. Why not. I folded two of the ears up and pulled the “motherboard” out. A pair of multi part thin brass/copper (?) contacts mounted on a piece of resin, activated by a plastic rocker. There are 2 contact areas per side (stacked up), similar to sanding a set of points, I turned some fairly cankered contact areas nice and shiny clean with some 1000 grit.
We’ll see soon if it’s really that simple.
Old 04-21-2020, 04:26 PM
In my case, taking the switch apart, cleaning it and reinstalling was the cure.
Driver switch is about to come out now.
Old 04-21-2020, 04:38 PM
sweeeeeeeeeeeeeeet
be nice pulling the switches out of the retainer ring thats bent over the door panel also...........
Old 04-21-2020, 04:51 PM
Driver switches now work.
Old 04-21-2020, 04:53 PM
better pull em and sell em while they are still working ?? !!
nice job ... 2 more to go .....
Old 04-21-2020, 06:04 PM
Nah, the back windows worked 15 years ago. Why tempt fate by trying them......
