Special 2 piece 400 Crankshaft Found Today
Check out what I found in this 400. Not a good thing to find. Late 70's 400.
2 pieces now. Sent from my Moto Z3 Play using Tapatalk
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
If they fracture just right, they still run. The knock is rather odd.
The Following User Says Thank You to einstein For This Useful Post: | ||
Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
An 800HP shot of nitrous from a stand still will do that.
well, photo 1 clearly shows a hole!
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
I had one of these cranks in a 76 455 TA engine... It still ran just knocked a lot!
https://www.facebook.com/PaulKnippen...9523455937204/ Very rare option |
. Drill hole.
Made me look at CYL 1; looks like a dented lower CYL.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
I once bought a real nice '66 GP with an engine knock. Drove it about 20 miles home with the A/C blowing ice cubes. Took it apart, and the crank was in 2 pieces. |
Great picture to show the "overlap" of rod and main journals. There isn't as much as you would think when viewed from this angle.
Very glad my factory 455 crank has larger mains to maintain as much overlap as possible!
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
This happened the last 25 miles of a 3000 mile trip. The oil pressure hovered around 20 and she knocked like hell, but she made it all the way home.
-Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5 1933, 1934, 1936 and 1940 Fords, also Pontiac powered. |
#1 main brg. Spun .When I pulled timing set off , the one side of the main brg slid out. Took rod nuts loose and there was lots of movement of the broke part of crank.
Main cap is chipped around dial pin. Cylinders look good, so far. Align hone/bore and replace crank/main cap and it may be good to use. Going to put another short block in it's place to sell. Sent from my Moto Z3 Play using Tapatalk
2.8 GM V6...Drove it home. Clutch was a little squirrely though!
Jimmy M 68 GTO |
had one break just like the one in the first pic.
most people said that a bad ballancer caused it.
67 gto 400/400/3.90(sold) 69 lemans vert 400/400/2.78 89 trans am 350/700r/3.27 67 lemans custom |
