strongest manual tranny
Anybody out there tried diff manual trannies? Which one do you think is the strongest for street and strip? for 500 to 600 hp
www.bowhanger.com 468 poncho powered 66 cutlass 77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html |
Used my Muncie behind a 454 chebby, with NO2 and slicks, no issues. Now that trans is in my trans am 455, no issues except no overdrive LOL
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Tremec TKO 600 is my reccomendation. And for serious abuse the same unit with "Liberty Gears" (Detroit, Michigan) treatment and enhancements.
Tim john--- |
The strongest manual that I know of is the Dearborn 3 speed.
GM had a test for stick shift cars called the Bonzai Test and the Dearborn was the only one that survived.
X2
I know a guy who abuses his cars like crazy - his TKO600 held up for years behind 700 HP on engine and even put nitrous through it as well. |
X 3. But I might be biased.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
I went through two m-21's, and one super t-10 before getting a tko 600.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Absolute strongest? Tranzilla from Rockland Gear is rated 1,000 ft.lb. and 1,200 HP.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) Last edited by Jack Gifford; 02-07-2013 at 01:53 AM. |
I've been useing my top loader for over 20 years.
GT. |
Ever hear of Auto gear out of NY? had a guy tell me about them and I called and talked to them looks like they build a muncie clone called a m 23 along with some others that are supposed to be very strong. Any feed back from anyone
I'm looking closely at that transmission as well. Basically a beefed-up M22. They make them with 3 different gear ratios, 2.20, 2.56, or 2.95 1st gear iirc.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
I have one - essentially they use beefed up parts; ie iron midplate, Supercase, etc. I did not want to deal with Keisler and his empty promises anymore and did not want to butch up my Lemans floor pan. I am leaning TKO 600 for the T/A, mainly for the 0.82 overdrive as I feel .67 is a bit much...
Jericos on the race side. Although one of my Mopar NSS firends has a Liberty box in something like a Muncie case.
My TKO has about 1500 miles on it now.
Guess I need to go out and drop the clutch......
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
i also bought a Auto Gear M-22, didn't get the M-23 option , but did get everything else. First gear is 2:20, looking for a deal on a Gear Vendors unit and finish the car and have some fun. John
When considering what is strongest you must consider how you are going to use it. If you don't use tires that hook then most any suggestion here will work. If you are going to run it hard then you will likely need give somewhere...in the clutch or at the tire or some of both if not something will go boom. The TKO do offer the O/D and if you street drive it and have a highway streetable engine they seem like a good choice. I am going to a G-Force with the 535 I am putting in. |
And to get right to the point...the strongest (in no particular order) are Liberty, G Force and Lenco. They are pricey but will handle 1,000+ HP at some obscene weights.
Quit being a wuss. I was beating on mine after about 250 miles! I have about 1500 on it now as well and since it is currently on the floor in the garage, I suppose I should change that stupid expensive fluid.
I have the .67 and if I had it over to do again, I would go with the .82 OD with a 3.23-3.42 gear. That being said, crusing around at 75mph @ a bit less than 2000 rpm is kinda' nice too.
I like it.
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
