Old 06-12-2016, 03:38 PM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default 65 Bonneville lower ball joins swap
Hi friends,
Just saw that my lower all joints having much play...I greased them but still play...
I have bought a few years ago a new set from Ram performance..
Now it's time to do the job .. I already replaced the lower and upper control arm bushings but not the ball joints ..
How i have to do the Job ? Have i to Build the complete Control arm from the Car or can i replace the lower ball joints without removing the Control Arms ?
WHO have already done this job ?
Thx for any help !!
Bjoern Poncho
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 06-12-2016, 07:15 PM
stevep's Avatar
stevep stevep is offline
If your car was built before January 1965 (or so) the lower ball joints may not be replaceable and you will need to replace the lower control arms. if there is a plate welded under the joint, you are changing the arms. I'm going through this right now with my car.
Old 06-29-2016, 02:46 PM
GTM GTM is offline
Send a message via Yahoo to GTM
I have the same situation. My control arms have the welded plate. But the new ball joints line up and fit good or so it seems..I cut off the welded plate. Im not sure what to do..
Old 06-29-2016, 10:19 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Replace the lower control arms with units off a 66-70 b body Pontiac. If you have the plates welded on or the early 65 arms with the curved lips, the ball joints are not to be replaced.
The plate was added in production after reports of the control arm breaking at the ball joint. They purged the warehouses of the original style arm mid December 1964, replacing it with the one with the welded plate. After the 66's came out, that became the service replacement for the 65's...
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 06-30-2016, 09:28 AM
Engine-Ear's Avatar
Arrow Bjoern, search this subforum...
I keep misplacing the thread, but in this subforum I posted years ago the VIN 'cutoff' broken out my final assembly plant whether the front suspension is the early or late design (on the '65 model year DarkSiders).
This isn't what I was thinking of, but one of the (seemingly) several times I have posted this... http://forums.maxperformanceinc.com/...pension&page=2 ...go to post #26. Hope it helps!
Old 06-30-2016, 09:40 AM
LASJayhawk's Avatar
This is a separate front end issue covered in News Flash 65-42 dated 11-23-64.
I'll try to rescan the document as a jpeg and post later today or tomorrow.
Old 06-30-2016, 10:39 PM
BILL BOWMAN1's Avatar
This is the first I heard of this. Of course I had to go look, thankfully no plates or curly edges!
Old 06-30-2016, 11:21 PM
GTM GTM is offline
My 65 GP is a C143xxx and has the plates and curled edges..what Im hearing is that in late 64 Pontiac decided the arms were weak and the factory welded the plates to the arms..thr cutoff VIN was when the 66 style arms were installed from thw factory and the curled ones discontinued forever.
I decided to remove the plates, install the balljoints and reweld the plates back in place. My GP has gone 155,000 miles in the plated arms with no problems so Im keeping it that way.i believe arms with the plates are safe but incinvenient when ball joint replacement is necessary and NOT a defective part...
Old 08-26-2016, 05:26 AM
Default 1965 Bonneville Catalina lower A arm ball joint
[Hi guys,
just removed the lower control arm and drilled out the lower ball joint ...
before i cuted the matal plate (first style early 1965) ...
now i`m replacing the ball joint ...screw them in with the sheet metal plate back in place and will weld it in ...
Any way the 3 screws should be go in the ball joint ? Which direction? Doesn't matter ? From top or lower side?
[/FONT]
Thx for any help !
ID:	435493   Click image for larger version
ID:	435494   Click image for larger version
ID:	435495   Click image for larger version
Old 08-26-2016, 05:28 AM
Thx for the link ...exactly the situation
Old 08-26-2016, 09:05 AM
Willshire's Avatar
Willshire Willshire is offline
That's almost exactly what i did to my 64 gp
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 08-26-2016, 09:36 AM
GTM GTM is offline
Lower ball joint bolts MUST be installed from the top down or the steering arm will contact the bolt stud when turning
