OHC-6 TECH Over Head Cam projects, questions and advice.
Old 05-20-2017, 08:52 AM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
Default waht is the rocker arm ratio
what is the cam follower ratio in the ohc 6 1.5 or 1.65
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 05-20-2017, 01:00 PM
Jeff Hamlin's Avatar
Old 05-21-2017, 12:56 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Interesting that those specs list it as "rocker arm" ratio. Since a "mean" (average) value is specified, the ratio must vary somewhat through the lift range.
Old 05-21-2017, 12:05 PM
Bill Hanlon's Avatar
It would Jack. As the lobe comes around the contact point on the "rocker" would be "sliding", changing the contact point and therefore the ratio.
