Triopower Small Center Carb
There you have it--97 pieces are used in the center carb used for Pontiac Tripowers from '57-'65. The automatic version had five more pieces for the hot idle vent. When restoring these carbs, every one of those pieces needs cleaning/plating/dichromating, or replacement. The jetting and venturi cluster idle circuits were unique to each engine---cubic inches, cam, transmission, etc.
The '57-'65 center Tripower carb saw only minor changes for the nine years Pontiac used that carb for Tripowers. From '61-'65, the venturi opening was enlarged to 1 1/4". Some of you are aware that the "larger" center carb used in '66 actually had a venturi opening measuring 1 3/16"-- smaller than the "small" center carb. The '66 obviously had larger throttle plates, but the venturi was smaller. I think Rochester did that to improve throttle response with the '66 setup.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
