What do I have here? Alternator bracket
Got this
In box of Parts. Thought it was 1963-4 alt bracket but I do not think so Anymore as I can’t Find the part number. Thanks in advance
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
for sure not a 63.Tom
Damn if you don’t know what it is no one will lol
The 978 code was first used in 65.
I do stuff for reasons. |
This the part number ?
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I'm sure that was part of our 68 Firebird alternator when we purchased the car.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
Pic of a 63 Alt bracket on my 69 bird engine.
1965-67 Pontiac With (Ca) Smog Alternator
Used Bracket 9786904. Read Ad Jan 13, 2022 • THIS IS A USED ALTERNATOR BRACKET FOR I BELIEVE (CA) SMOG SYSTEM FOR PONTIAC. HAS 9786904 ON IT. Is this not correct?
The Following User Says Thank You to turbo69bird For This Useful Post: | ||
I can see the A.I.R. port on the bracket so that will limit it to the years that system was offered. No provision for power steering on the bracket so it would only be used for manual steering equipped cars.
PY parts lookup says 1967 if number is 9786904.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. Last edited by lust4speed; 11-07-2022 at 02:55 AM. |
The Following User Says Thank You to lust4speed For This Useful Post: | ||
Looks similar to the lower bracket for alternator/power steering pump. Bolts to the driver's side head. Not exact as the one that was on my 69 428 GP., But similar
thanks guys the rest of the parts are 68 firebird so that makes sense.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction Last edited by mysticmissle; 11-07-2022 at 08:04 AM. |
9786904 is for 1967 P/8-T/8-F8 S.S. Delcotron mtg.-w/A.I.R.-exc. 62 amp.
S.S. is Standard Steering. |
I have that same bracket on my 69 gto
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
1967-69 P/8, T/8, F/8, GP/8 and 1970 P/8, T/8, GP/8 w/P.S. uses the #9786903 bracket.
