400turbo trans question
if any of you guys are familiar with transmission problems i have a
question.I had the front and rear seals replaced on my trans becouse of leaking problems,but afterthat the trans stop changing out,it pops in every gear just fine even moves fine in reveres she just wont shift,i also had a straner put in so im just clueless,the way it goes in gear so good it can't need rebuilding. |
check to make sure the vacuum line is connected to the modulator.
Matt M is correct,
The 1st thing to check is the vacuum line to the modulator. If that is connected on both ends, check out the small rubber lines that connect the vacuum line. If no problems are found there, try swapping in a modulator you know is good. I dought that is the problem, but it only takes a few minutes. If it still won't shift, then the clutches are probebly burned out in the trans, you mentioned "leaks", and that usually means running the trans with a low fluid level. That usually causes the trans to run to hot, and that can asily burn the clutches. I had that happen to me a couple of times in the past. Good luck with it.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
sounds like a bad govenor gear to me. they tend to apple core and won't let the trans shift when they fail.
the mod is the first thing to look at, if there's fuild in the vac line side it's junk. if it's dry it's probably not bad. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
