#81
Look in the curved area between trunion and valve end of the rocker arm.
That's where you'll see a witness mark if there's a clearance problem. The retainer is a bit harder than the aluminum rocker. Clay |
#83
Move your pump rod to the middle hole on carb and make sure you are feeding full 12volts to your hei and not using the original resistor wire.
#84
Wait Untill
I wouldn't be surprised if the engine runs fine when it's all back together.
If the backfire was from a lean condition...it could easily be from a piece of trash that got lodged in a jet. Now that the carbs been off and shook around a little...That possible piece of trash could be laying in the bottom of the bowl. Backfire would be gone UNTILL that piece of trash finds its way back in a jet. Just thinking out loud Clay PS, most common trash found is a sliver out of the inside of a rubber hose |
#85
The prior owner of my car had a similar issue. He was running the 1.7" installed height springs on RA IV heads and had a paper trail of receipts for changed lifters, springs, retainers. etc. chasing valve train noise. His solution was to grind notches in the underside of the roller rocker rails for clearance! lol Turned out he was running Dport (short) pushrods causing his problems. I wound up installing Dports with RAIV valves and 1.7" installed height springs and RAIV (long) pushrods and -.050" keepers as a final to get the necessary clearance. Re: springs, I thought yours was a fresh engine but you say you have run it this way for 10 years?
Triple Black 1971 GTO |
#86
These rockers have a relief cut into them in that area. Plenty of clearance.
#87
After the cam break in I had a weird tick and then some backfiring out the carb. I took the intake and valley pan off to see if anything went wrong with the lifters on break in. Everything looked great. This morning I'm putting the distributor back in and I found something funny. There's a small cover next to the module that hides the wire connection. That small cover cam loose and wrecked havok inside the distributor. See pic below.
https://share.icloud.com/photos/0KKH...r_Township,_MI |
#90
It sure did! Does the mechanical advance still work?
#91
You know I'm extremely happy and relieved. Funny sounds and backfiring right after a cam break in can ruin your day, week, month.... Glad it didn't happen during the break in.
There were all kinds of chunks of plastic around the pick up. Not sure if the advance was damaged. |
#92
In your thread on HEI problem, did you run the distributor?
HEI Problem Your new rotor: Your last pic of the rotor that was running: What's the odds that they both have the rotor tip pointing like that? Also with a timing light it would have been abundantly clear there was a problem? I'd look at the cap also, it's probably cracked (or worse)
#93
My wife has been paying attention to the details and I asked her the same thing. What are the odds of having a rotor pointing up twice like that? Life is strange. Definitely replaced the cap too. |
#94
One Like This?
Was it a black plastic piece like this?
Exactly when did all this happen? Breakin or after you did all the work and went to fire it up again? And is it running now? Too much suspense Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
#95
It was fine until I shut it down after the cam break in. It must have caught on the rotor on the very first start up after that. Started making funny noises and backfiring out the carb. Kind of like a bad lifter. Had to take a look at the lifters. They are fine. I was finishing putting it back together this morning. First chance I had. Took the cap off to put the distributor back on and found it. Haven't started it yet. |
#96
Parts flying loose from that may be what did the other damage with that cover. Clay |
#97
It runs good. Still has more valve noise than it had with the smaller cam. Ran it for another 20 minutes at 2000 rpm just to make sure the cam was completely broken in. Not sure what more I can do to get rid of the extra valve noise. Might have to live with it.
#98
Could the noise be the sound of the valves snapping closed from a more open position with the bigger cam? Does that make sense?
#99
Your Other Thread Post
How much preload did the new lifters call for? How did you check the preload? What technique did you use to lock the polylocks down? Need to turn the nut for the final lock instead of just tightening the set screw. Clay |
#100
One half turn lash after the push rod doesn't move up and down anymore. After I have the half turn lash then I held the nut with a wrench so it didn't turn and tightened the set screw. |
