need help to i.d a wire on my engine bay harness
got a new harness for my engine bay for my 72 formula , what is the brown wire for
sorry here is the photo
Its for the tach
I recall having to buy this separately from the main engine harness
1970 RAIII white/blue |
The Following User Says Thank You to RamAirPwr For This Useful Post: | ||
thats what i thought , but my tach connector will not go into the new connector
does this plug into my tach harness . it seems that the two connectors are the same (male ) anyone have photos
Is that an orange tracer? If so, it's to the shaker on a T/A.
Not sure what you mean
Does that wire have an orange stripe on it or is it a solid color?
I think it solid brown
If it's solid brown it's usually a tach wire. Is it a unitized ignition car or points?
do you have a wiring diagram for it?
No it is a points car
Any one have a photo of how it hooks up. Did some research and the connector at the end of my tach harness must be for a unitized dist . I guess in need the wire with the little hook so can put it on my coil
You must have purchased a unitized harness. At this point, I would most likely change the terminal end unless this is a concourse restoration.
i guess i need the connector with the clip for the coil like in this photo
Sounds that way.
also need to know were the coil mounts . my car was missing the coil and the bracket
The last bolt on the drivers side intake manifold.
