#41
What is a ucu?
My Half AN Injun..... |
#42
Charlie,
I think he meant ECU. |
#43
My ecu is Fast XFI 2.0
Thanks Ed.
#44
Yes, ecu, sorry... I'm not familiar with that system. Maybe PM Lee Atkinson. He's a FAST dealer and works with it.
Maybe this will give you a direction to look. https://www.yellowbullet.com/threads...ngine.1564626/
#45
I bought a little device that converts the tach to work with 4 cylinders. Ill be getting it tomorrow. The tach cant work with a 4 cyl. Its a old 8 cyl tach.
#46
That's cool. There's some pretty serious magic inside some of these ecu's.... I was envisioning the possibility of a programmable output at 2x engine speed or something of the sort. Hope your adapter does the trick.
#47
But i broke the car yesterday so thats on hold until i fix the car. Theres always something .. Thanks..
#48
Uh oh... Sorry to hear that. Did you get your suspension sorted before it broke?
#49
No i didnt.
#50
There will be an adjustment potentiometer inside. If not, they are easy enough to add. Soldering and electrical circuit skills are needed.
For the input signal, V8s are 15 rpm per hz and a 4 cyl is 30 rpm per Hz. If using 55 to 60 deg dwell, set the function generator for 65% negative dwell. 12v square wave output. Using the frequency counter, adjust the generator frequency using the scaling above. Adjust the potentiometer to get the proper rpm readings. May have to replace the charge pump capacitor in the tach with a different value but that is easy enough. Sent from my SM-T817V using Tapatalk Last edited by 70GS455; 06-02-2020 at 12:25 PM. |
#51
I have no idea what you just said.. lol What is a function generator? Thank you
#52
Sent from my SM-T817V using Tapatalk |
#53
Sounds like you know your tachs.. I bought a tachometer converter. But now im having trouble understanding how to set it up..
#54
#55
I got it all working . That widgit thing worked great..
#56
Charlie, good to know the Widget works as described by the manufacturer.
#57
Theres alot of options for other tachs as well. Thanks for the link Man! Much appreciated!
