Old 04-12-2020, 08:57 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Tachometer inaccurate
When I restored my 67 GTO I bought a new repo tach. I think it was from the parts place but I can’t remember for sure. I’m pretty sure it’s not very accurate but don’t know if there’s a way to adjust it or calibrate it. At 60mph the tach is reading 2900 rpm and I believe it should be around 2500. I’ve verified my speedometer is within 1mph based on gps speed.
The 2500 rpm figure is off my 1:1 trans gearing, 27” tire, and 3.36 rear gears.
I have a sunpro tach for one of my other projects I. Going to hook up this week and compare them side-by-side but I’m definitely thinking the tach in my car is off. If I can’t fix or adjust it I’ll probably upgrade to a rally gauge cluster next winter
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 04-13-2020, 05:25 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
I have a Pertronix Digital HP box and it has a tach calibration feature. You tell it what rpm and it sends a steady signal to the tach. My factory tach is 10% fast at all speeds. Most of them are, probably to keep people from blowing engines under warranty.
The Digital HP also sends a signal to the tach to flash to the set rev limit when you turn the key on to start.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 04-13-2020, 09:45 AM
Formulajones's Avatar
Formulajones Formulajones is online now
Hmmm, Are you figuring in converter slippage with your formula?
I'd compare it to another known good tach before I made any decisions, or simply hook up an old dwell meter that has a tach function. My old Dwell meter has an excellent analog gauge movement on it that is very accurate.
I installed a hood tach on dad's GTO a couple years ago, I think it was also from the Parts Place. I always wondered how accurate it was. it seemed to be pretty close from my calculations. Well this weekend he wired up an Autometer shift light that has a digital tach readout in 10 rpm increments on it. Had them both running simultaneously and found that hood tach is exactly correct. It's a little slow to move up and down when you rev the engine, but at steady RPM it dead nuts.
Just an FYI, some of the aftermarket circuit boards used in the OEM repop tachs today have a calibration screw on them. If it has one, it's a little brass screw on the end of the circuit board. have to completely disassemble the tach to get to it. It's there for the technicians to calibrate the tach before it's sent out and not really there for us to tinker with, but it's an option if need be.
Old 04-13-2020, 09:56 AM
Here's a place that sells new circuit boards. If you don't see a specific application listed there you may have to call. Some of these have an adjustable calibration.
https://www.cajuntachshop.com/shop?page=3
Old 04-13-2020, 10:00 AM
389 389 is offline
I have a hidden shift light... The cable driven tach's seemed to be the most accurate..
Old 04-13-2020, 02:48 PM
lust4speed's Avatar
Just to add another variable in to the mix we have had two different GPS programs running on separate cell phones and they themselves were a couple MPH different when we were trying to verify the car's speedometer. Makes it tough to check things when your checking devices won't agree.
Mick Batson
Old 04-13-2020, 03:04 PM
Can't even trust those digital speed limit signs either. They have them on the highway, a few of them about a mile apart from each other. I was going 65 and the first one said 66 so I was good with that. The next one said 74 mph, I was still going 65 lol. I was the only car on the highway.
Old 04-13-2020, 08:26 PM
67gtospud's Avatar
I didn’t account for any converter slippage since my car is a 4 speed manual. I don’t have a dwell meter but I will compare it to another tach and see what the results are.
Old 04-15-2020, 04:48 PM
70GS455 70GS455 is offline
To answer the question, yes they can be calibrated and adjusted. Just need someone with a signal generator and frequency counter...like myself
Sent from my SM-T817V using Tapatalk
