Old 04-17-2020, 05:14 PM
64speed's Avatar
64speed 64speed is offline
Default Wheel stud knurl
I converted my 64 to 68-72 style front disc brakes. One of the studs pressed out and I damaged the threads trying to get it back in. The only studs my local parts store can look up in their computer cause they’re a bunch of teenagers is for drum brakes and it’s knurl is too small. The lug stud is 7/16-20 thread but what’s the knurl size?
Old 04-17-2020, 06:28 PM
Scott Thelander's Avatar
I have spare 67-69's 2 part rotor lug studs
and
70-72 1 piece
or tap one of the others out
Old 04-18-2020, 10:08 AM
64speed's Avatar
I was a teenager in a parts store once and I knew how to use a catalog or did thru all the boxes with a dial caliper
Old 04-18-2020, 10:34 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Why not just get a stud for a 68 -72 GTO with disc brakes????
64 Lemans hardtop
4spd, buckets
Old 04-18-2020, 11:08 AM
grivera's Avatar
grivera grivera is offline
Originally Posted by 64speed View Post
What?
- I believe he's referring to your thread below (post 14)
http://forums.maxperformanceinc.com/...d.php?t=835524
(Post 14)
http://forums.maxperformanceinc.com/...8&postcount=14
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 04-18-2020, 01:06 PM
David,
Why not take measurements and look it up in the buyers guide? Only have to open one box that way if it's in stock.
FWIW you can still do this online, then call the parts store with the part number you need.
BTW Dorman catalog does not have a listing for this application. That means the part store computers won't have a listing.
New kids will never know if we dont teach them
Some actually care...Some don't
Clay
Old 04-18-2020, 01:39 PM
64speed's Avatar
I didn’t strip the hole in the head by the way I just thought I had. I found it. The kid at Oreillys was looking at a drum brake application and never made an attempt to dig further. The parts pro at NAPA an ancient man by the way walked right to it.
Old 04-18-2020, 01:42 PM
Tom Vaught's Avatar
Boost Engineer
THIS IS IMPORTANT:
IF YOU GET THE WRONG SIZED KNURL ON THE WHEEL STUDS,
YOU HAVE A VERY HIGH CHANCE OF CRACKING YOUR ROTORS
AT THE BOLT HOLES AND THEN GUESS WHAT?
YOU ARE BUYING NEW ROTORS.
I saw a mechanic do that on a 64 GTO one time with replacement new rotors.
Then the mechanic says to the Garage Owner: I just installed the studs car owner
gave me, How was I to know the studs were the wrong ones?
DO SOME INVESTIGATION AND MEASURING BEFORE YOU TRY TO FIX THIS LATEST SITUATION.
So I agree with all of the above comments.
Just take your time and get the right parts.
Tom V.
Old 04-18-2020, 02:04 PM
mchell's Avatar
mchell mchell is offline
Look at the Dorman 98004.1
.564 knurl
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 04-18-2020, 02:29 PM
grivera's Avatar
Partially strpped?
http://forums.maxperformanceinc.com/...light=helicoil
Will Rivera
Old 04-18-2020, 06:21 PM
64speed's Avatar
610-025 Dorman is the part number we came up with. Seems to be right and it comes up in a 70 GTO search
Old 04-19-2020, 09:17 AM
mchell's Avatar
610-025 is the same stud as the 98004.1.....10pk vs single stud
The Following User Says Thank You to mchell For This Useful Post:
Old 04-20-2020, 06:06 PM
70GS455 70GS455 is offline
Dorman 610-186
Sent from my SM-T817V using Tapatalk
Old 04-20-2020, 06:30 PM
mchell's Avatar
This might help
https://www.dormanproducts.com/gsear...l%20Lug%20Stud
Lists the 610-186 as a rear wheel stud with a .472 knurl
Old 04-20-2020, 06:53 PM
64speed's Avatar
It’s the 610-025 confirmed by the rotor manufacturer. In related news I was able to install the new stud without taking the hub or the dust shield off. I fed it thru the hole in the dust shield till I could pull it thru the rotor with a magnet. I put red loctite on the knurl then held it in place till I got the lug started and then used a breaker bar to pull it thru the rotor so crisis averted
Old 04-20-2020, 09:44 PM
STEELCITYFIREBIRD's Avatar
Old 04-20-2020, 10:44 PM
64speed's Avatar
Originally Posted by STEELCITYFIREBIRD View Post
This is what I kept asking for but they kept giving me drum brake studs
Old 04-20-2020, 11:42 PM
that made MY brain hurt ......
The Following User Says Thank You to Scott Thelander For This Useful Post:
