Old 04-22-2020, 07:56 AM
grd777 grd777 is offline
Default need help to i.d a wire on my engine bay harness
got a new harness for my engine bay for my 72 formula , what is the brown wire for
Old 04-22-2020, 07:57 AM
sorry here is the photo
Name:	IMG_3094 (002).jpg
Old 04-22-2020, 11:36 PM
RamAirPwr RamAirPwr is offline
Its for the tach
I recall having to buy this separately from the main engine harness
1970 RAIII white/blue
The Following User Says Thank You to RamAirPwr For This Useful Post:
Old 04-23-2020, 07:40 AM
Originally Posted by RamAirPwr View Post
Its for the tach
thats what i thought , but my tach connector will not go into the new connector
Old 04-30-2020, 11:50 PM
does this plug into my tach harness . it seems that the two connectors are the same (male ) anyone have photos
Name:	IMG_3143 (002).jpg
Old 05-01-2020, 10:27 AM
necdb3's Avatar
necdb3 necdb3 is offline
Is that an orange tracer? If so, it's to the shaker on a T/A.
Old 05-01-2020, 06:35 PM
Not sure what you mean
Old 05-01-2020, 08:25 PM
necdb3's Avatar
Does that wire have an orange stripe on it or is it a solid color?
Old 05-02-2020, 08:29 AM
I think it solid brown
Old 05-02-2020, 10:57 PM
necdb3's Avatar
If it's solid brown it's usually a tach wire. Is it a unitized ignition car or points?
Old 05-03-2020, 03:33 AM
Aus78Formula Aus78Formula is offline
do you have a wiring diagram for it?
Old 05-03-2020, 07:49 AM
No it is a points car
Old 05-03-2020, 07:50 AM
Sorry I do not
Any one have a photo of how it hooks up. Did some research and the connector at the end of my tach harness must be for a unitized dist . I guess in need the wire with the little hook so can put it on my coil
Old 05-03-2020, 10:06 AM
necdb3's Avatar
You must have purchased a unitized harness. At this point, I would most likely change the terminal end unless this is a concourse restoration.
Old 05-03-2020, 06:10 PM
i guess i need the connector with the clip for the coil like in this photo
Name:	IMG_3147 (002).jpg
Old 05-03-2020, 09:33 PM
necdb3's Avatar
Sounds that way.
Old 05-04-2020, 06:55 AM
Sounds that way.
also need to know were the coil mounts . my car was missing the coil and the bracket
Old 05-04-2020, 12:20 PM
necdb3's Avatar
The last bolt on the drivers side intake manifold.
