Old 06-10-2024, 02:20 PM
lovedemnewfies's Avatar
lovedemnewfies lovedemnewfies is offline
Default 1965 GTO reverse lights
Having issues with the reverse lights staying on when car is not in reverse. Anyone one have a wire diagram or possible things to check? It was weird because I’ve never seen them on with car in neutral. Also had to pop start it today as well, which it’s never gave me any issues in the past. Thanks for any help
Chris
Old 06-10-2024, 06:17 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Wiring diagram for ya. Hopefully this helps, maybe linkage fell off trans? OH is this a Auto or std?
64 Lemans hardtop
4spd, buckets
Old 06-10-2024, 07:23 PM
Sorry forgot to say it’s a Muncie 4 speed
Old 06-10-2024, 07:36 PM
I don't think they had the reverse lockout setup like 70 and newer.
But I'd say the neutral and reverse light switch is out of adjustment?
Not sure where it is in 65, but probably on the tranny linkage.
Old 06-10-2024, 08:59 PM
Thanks. I’ll get under it and see what’s going on. Appreciate the help
Old 06-12-2024, 11:49 AM
Peter Serio's Avatar
Default Back-up lamp switch= Muncie 4 speed transmission
Here is a jpeg from a long time ago. This is a 66 GTO 4 speed transmission but a 65 GTO would be the same as far as that reverse lamp switch and wiring goes.
Where the twin wires pass thru the rubber boot in the firewall (right beside the fuse block) the plug it connects to underneath the dash, the dash wires are color coded: one is lime green and the other one is dark green.
The wires outside of the firewall and underneath the car to the actual switch are not color-coded.
As I recall that zip cord "twin" wire is dark grey and/or black.
ID:	635222   Click image for larger version
Peter Serio
Owner, Precision Pontiac
The Following User Says Thank You to Peter Serio For This Useful Post:
Old 06-13-2024, 07:41 PM
Thanks a bunch for the pics and info. It will help a ton.
