Old 01-05-2018, 12:02 PM
Jpaul Jpaul is offline
Default 57 duel fuel pump
Just bought an original 57 chieftain, it has a single fuel pump with the vac wipers plumbed to the 2 barrel carb. What if any is the advantage of having the duel fuel pump, as I believe that it's lines go to bother the wipers and carb.
Thx
Jpaul
Old 01-05-2018, 12:49 PM
694.1 694.1 is offline
Dual diaphragm pump is for the operation of the Vacuum wipers. Cores are not hard to find. Congrats on your car, we want pictures!
What can you tell us about it?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 01-05-2018, 08:13 PM
U47 U47 is offline
Thx
Jpaul
Advantage, dual action pump provides vacuum at all times. With the vacuum plumbed to the carburetor or manifold vacuum every time you opened the throttle the vacuum signal goes way down. If you were getting on the FWY and it was raining and had the wipers on the sudden acceleration and wide open throttle would stop the wipers until you backed off and manifold vacuum was restored.
Old 01-05-2018, 11:33 PM
fyrffytr1's Avatar
If you find the correct core here is a link to a quality rebuild kit. I used one on my 50 Pontiac. I don't know if they have a pump but you could ask.
http://www.then-now-auto.com/
