Old 11-19-2023, 06:36 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Trans Am Formula steering wheel fit a 65?
I have an extra Trans Am collar and Formula wheel will it fir the 65 GTO non tilt column? Original wheel REAL rough. I slid the GTO wheel on the extras 79 Camaro column I have so splines seem the same.
Skip Fix
Old 11-19-2023, 08:10 PM
It fits.
My ‘64 had that exact setup when I first bought it and I raced it for many years that way.
Old 11-20-2023, 10:35 AM
Skip Fix's Avatar
I have all the parts, repop collar does the pain need to be cleaned off inside fore the horn contact?
Skip Fix
Old 11-20-2023, 01:00 PM
Original collars have a fairly widespread coating of paint on the backside. My only concern would be if one used the wrong horn contact pieces. Over the years have had a 67 project car & a 68 parts car that prev owner had swapped on a thick Formula wheel. At least with the '67 GTO, the canceling cam & horn worked.
Old 11-25-2023, 12:45 AM
giles's Avatar
giles giles is offline
I installed an early 70s Formula wheel on my ‘64 Tempest while I restore the cracked original wheel. Works great, horn, signals, etc.
Old 11-26-2023, 02:40 PM
They fit most GM, AMC and even some MOPARs. I used 1 years ago on my 1963 Chevy pickup.
