Me again, sorry about all the questions but I'm new. Is there a good way to upgrade to roller bearings instead of the stock ball bearings in the front hubs? Disk brake swap? Thanks
If you keep your stock drum brakes, there is a roller bearing available that will fit in the place of the old ball bearings. I imagine there are other ways to get them, but the one I know of is on eBay - there's a guy on there selling them all the time. I believe he goes by the name, "gmpartsplace."
I just checked and didn't see any on auction right now, but check back there periodically and sooner or later he'll be there. |
I just check. He has the 4 bearing for $125. Seems awful pricey. Anyone know what the inner and outer bearing parts numbers are? I'm sure I could find them cheaper.
Just use bearing from a later model(8 lug) available at any good aftermarket supplier such as NAPA. Seals also.
$125.00 + shiping sounds a bit much.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
The problem is, the outside diameter of the ball bearing races (mid-1961 and earlier) is larger than the later model roller bearing races (late-1961 and on), so they don't interchange.
When I put the 8 lug wheels on my '61 Bonneville I was lucky enough to find a set of '62 drums, so I was able to go down to the parts store and get new roller bearings without any problems. |
Hmmmmmmmmmm. I'll check my reciepts on bearings.
Did not run into a size issue when I converted mine. Maybe they were 62 drums. Any way, a GOOD parts person can find you a race with a larger diameter yet retain same bearing size. Takes a little time but it can be done. I worked for NAPA for 10 years.
The 59-64 spindles are interchangable acoording to Hollender Manual, so I bought some '64 roller hubs from a PY'er a while back to put on my '59. Just ain't found the round tuit to replace yet though!
If the races in the hubs have the same OD then you could just buy bearings and races. I thought of that after buying the hubs! Oh well I gotta good deal on 'em anyway. DanC
------------------------------ 1968 Firebird Convertable - my original HS car! 1978 Firebird Esprit "survior" 1930 Ford Model A Coupe .. (original) 1994 Buick .."TowMaster" ...woody wagon |
OK, this information is from http://www.teufert.net/pontiac/8lug/8lug.htm, it's a copy of the 8 lug data information that was compiled by Roger Riehl.
1958-1961 ball bearings: Inner 2.6487" OD, 1.25" ID: p/n #909070 Outer 2.0787" OD, .75" ID: p/n #909067 1958-1961 roller bearings (police & heavy duty) Inner 2.6487" OD, 1.25" ID: p/n #153213Y (also Hyatt p/n #LM67019) Outer 2.0787" OD, .75" ID: p/n #113158Y (also Hyatt p/n #LM11919) 1962-1984 roller bearings (all) Inner 2.329" OD, 1.25" ID: p/n #7450630 Outer 1.781" OD, .75" ID: p/n #7450627 Inner bearing seal, all with ball bearing and large cup roller 1958-1961: p/n #533249 Inner bearing seal, all with standard roller assembly 1962-1968: p/n #539161 So, the later roller bearings are about 0.3" smaller in outer diameter than the ball bearings. The trick is to find the heavy duty roller bearings to convert the earlier hubs. Maybe the Hyatt part numbers can be cross-referenced to a modern part number. |
A good friend bought a set of the conversion bearings from gmpartsplace off ebay and then priced the same races, etc. through NAPA and others. The prices quoted to him were way higher than what he paid on Ebay. They must be buying them in bulk or are selling NOS sets that they paid a lot less for?
If anyone needs/wants the original brgs. I have these.
$100
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
check with Pontiac heaven in PHX az. steve, I think has done a disc brake deal on a 60 wagon
Free shipping
MY BAD! I broke the rule by posting this.
So I listed them for half price in the for sale section. OGR
Great info Stuart, has anyone done a swap on 55-57 front spindles? I have a set of 8 lugs and would love to run them on my 55 wagon.
We were just talking about that in this thread: https://forums.maxperformanceinc.com....php?p=6425704
